Datasheet ADL8150 (Analog Devices) - 5
DescriptionGaAs, HBT, MMIC, Low Phase Noise Amplifier, 6 GHz to 14 GHz
Pages / Page15 / 5 — Data Sheet. ADL8150. ABSOLUTE MAXIMUM RATINGS Table 4. ELECTROSTATIC …
File Format / SizePDF / 251 Kb
Data Sheet. ADL8150. ABSOLUTE MAXIMUM RATINGS Table 4. ELECTROSTATIC DISCHARGE (ESD) RATINGS. Parameter. Rating
Data Sheet ADL8150 ABSOLUTE MAXIMUM RATINGS Table 4 ELECTROSTATIC DISCHARGE (ESD) RATINGS Parameter Rating
link to page 15
Data Sheet ADL8150 ABSOLUTE MAXIMUM RATINGS Table 4. ELECTROSTATIC DISCHARGE (ESD) RATINGS Parameter Rating
The following ESD information is provided for handling of Collector Bias Voltage (VCC) 6.5 V ESD-sensitive devices in an ESD protected area only. Radio Frequency Input (RFIN) Power 25 dBm Human body model (HBM) per ANSI/ESDA/JEDEC JS-001. Continuous Power Dissipation (PDISS), TA = 85°C 0.843 W (Derate 15.9 mW/°C Above 85°C)
ESD Ratings for ADL8150
Temperature Storage Range −65°C to +150°C
Table 6. ADL8150, 6-Lead LFCSP
Operating Range −40°C to +85°C
ESD Model Withstand Threshold (V) Class
Peak Reflow (Moisture Sensitivity Level 260°C HBM ±1000 1C (MSL))1 Junction Temperature to Maintain 138°C 1,000,000 Hours Mean Time to Failure
ESD CAUTION
(MTTF) Nominal Junction Temperature (TA = 85°C, 108.3°C VCC = 5 V, ICQ = 74 mA) 1 See the Ordering Guide for more information. Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability.
THERMAL RESISTANCE
Thermal performance is directly linked to printed circuit board (PCB) design and operating environment. Careful attention to PCB thermal design is required. θ JC is the junction to case thermal resistance.
Table 5. Thermal Resistance Package Type θJC Unit
CP-6-12 62.9 °C/W Rev. 0 | Page 5 of 15 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Frequency Range: 6 GHz to 7 GHz Frequency Range: 7 GHz to 12 GHz Frequency Range: 12 GHz to 14 GHz Absolute Maximum Ratings Thermal Resistance Electrostatic Discharge (ESD) Ratings ESD Ratings for ADL8150 ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Theory of Operation Applications Information Biasing Procedures Outline Dimensions Ordering Guide
