Datasheet ADL8150 (Analog Devices) - 4
DescriptionGaAs, HBT, MMIC, Low Phase Noise Amplifier, 6 GHz to 14 GHz
Pages / Page15 / 4 — ADL8150. Data Sheet. FREQUENCY RANGE: 12 GHz TO 14 GHz. Table 3. …
File Format / SizePDF / 251 Kb
ADL8150. Data Sheet. FREQUENCY RANGE: 12 GHz TO 14 GHz. Table 3. Parameter Min. Typ. Max. Unit. Test. Conditions/Comments
ADL8150 Data Sheet FREQUENCY RANGE: 12 GHz TO 14 GHz Table 3 Parameter Min Typ Max Unit Test Conditions/Comments
VCC = 5 V, ICQ = 74 mA and TA = 25°C, unless otherwise noted.
Table 3. Parameter Min Typ Max Unit Test Conditions/Comments
FREQUENCY RANGE 12 14 GHz GAIN 8 10.5 dB Gain Flatness ±0.9 dB Gain Variation over Temperature 0.034 dB/°C NOISE FIGURE 3.8 dB PHASE NOISE −172 dBc/Hz Measurement taken at 10 kHz offset from carrier RETURN LOSS Input 5 dB Output 8 dB OUTPUT OP1dB 15.5 17.5 dBm PSAT 21.5 dBm OIP3 30 dBm Measurement taken at POUT per tone = 6 dBm OIP2 60 Measurement taken at POUT per tone = 6 dBm SUPPLY ICQ 74 mA Self biased VCC 3 5 6 V Rev. 0 | Page 4 of 15 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Frequency Range: 6 GHz to 7 GHz Frequency Range: 7 GHz to 12 GHz Frequency Range: 12 GHz to 14 GHz Absolute Maximum Ratings Thermal Resistance Electrostatic Discharge (ESD) Ratings ESD Ratings for ADL8150 ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Theory of Operation Applications Information Biasing Procedures Outline Dimensions Ordering Guide
