Datasheet ADL8150 (Analog Devices) - 3
DescriptionGaAs, HBT, MMIC, Low Phase Noise Amplifier, 6 GHz to 14 GHz
Pages / Page15 / 3 — Data Sheet. ADL8150. SPECIFICATIONS FREQUENCY RANGE: 6 GHz TO 7 GHz. …
File Format / SizePDF / 251 Kb
Data Sheet. ADL8150. SPECIFICATIONS FREQUENCY RANGE: 6 GHz TO 7 GHz. Table 1. Parameter. Min Typ. Max Unit
Data Sheet ADL8150 SPECIFICATIONS FREQUENCY RANGE: 6 GHz TO 7 GHz Table 1 Parameter Min Typ Max Unit
Collector bias voltage (VCC) = 5 V, supply current (ICQ) = 74 mA and TA = 25°C, unless otherwise noted.
Table 1. Parameter Min Typ Max Unit Test Conditions/Comments
FREQUENCY RANGE 6 7 GHz GAIN 8 10.5 dB Gain Flatness ±1.0 dB Gain Variation over Temperature 0.033 dB/°C NOISE FIGURE 4.8 dB PHASE NOISE −172 dBc/Hz Measurement taken at 10 kHz offset from carrier RETURN LOSS Input 2 dB Output 14 dB OUTPUT OP1dB 15.5 17.5 dBm Saturated Output Power (PSAT) 20.5 dBm OIP3 30 dBm Measurement taken at output power (POUT) per tone = 6 dBm Output Second-Order Intercept (OIP2) 32 dBm Measurement taken at POUT per tone = 6 dBm SUPPLY ICQ 74 mA Self biased VCC 3 5 6 V
FREQUENCY RANGE: 7 GHz TO 12 GHz
VCC = 5 V, ICQ = 74 mA and TA = 25°C, unless otherwise noted.
Table 2. Parameter Min Typ Max Unit Test Conditions/Comments
FREQUENCY RANGE 7 12 GHz GAIN 10 12 dB Gain Flatness ±0.5 dB Gain Variation over Temperature 0.024 dB/°C NOISE FIGURE 3.6 dB PHASE NOISE −172 dBc/Hz Measurement taken at 10 kHz offset from carrier RETURN LOSS Input 7.5 dB Output 8 dB OUTPUT OP1dB 16 18 dBm PSAT 22 dBm OIP3 30 dBm Measurement taken at POUT per tone = 6 dBm OIP2 44.5 dBm Measurement taken at POUT per tone = 6 dBm SUPPLY ICQ 74 mA Self biased VCC 3 5 6 V Rev. 0 | Page 3 of 15 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Frequency Range: 6 GHz to 7 GHz Frequency Range: 7 GHz to 12 GHz Frequency Range: 12 GHz to 14 GHz Absolute Maximum Ratings Thermal Resistance Electrostatic Discharge (ESD) Ratings ESD Ratings for ADL8150 ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Theory of Operation Applications Information Biasing Procedures Outline Dimensions Ordering Guide
