Datasheet HMC8142 (Analog Devices) - 3
Description81 GHz to 86 GHz, E-Band Power Amplifier with Power Detector
Pages / Page16 / 3 — Data Sheet. HMC8142. SPECIFICATIONS. Table 1. Parameter. Min. Typ. Max. …
File Format / SizePDF / 319 Kb
Data Sheet. HMC8142. SPECIFICATIONS. Table 1. Parameter. Min. Typ. Max. Unit
Data Sheet HMC8142 SPECIFICATIONS Table 1 Parameter Min Typ Max Unit
TA = 25°C, VDDx = 4 V, IDD = 450 mA, unless otherwise noted.
Table 1. Parameter Min Typ Max Unit
OPERATING CONDITIONS Radio Frequency (RF) Range 81 86 GHz PERFORMANCE Gain 19 21 dB Gain Variation over Temperature 0.02 dB/°C Output Power for 1 dB Compression (P1dB) 22.5 25 dBm Saturated Output Power (PSAT) 26 dBm Output Third-Order Intercept (OIP3) at Maximum Gain1 29 dBm Input Return Loss 12 dB Output Return Loss 8 dB POWER SUPPLY Total Supply Current (IDD)2 450 mA 1 Data taken at output power (POUT) = 12 dBm/tone, 1 MHz spacing. 2 Adjust VGGx from −2 V to 0 V to achieve the total drain current, IDD = 450 mA. Rev. A | Page 3 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION TYPICAL APPLICATION CIRCUIT ASSEMBLY DIAGRAM MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GAAS MMICS HANDLING PRECAUTIONS Storage Cleanliness Static Sensitivity Transients General Handling MOUNTING Eutectic Die Attach Epoxy Die Attach WIRE BONDING OUTLINE DIMENSIONS ORDERING GUIDE
