Data SheetHMC7543SPECIFICATIONS TA = 25°C, VDDx = 4 V, IDD = 450 mA, unless otherwise noted. Table 1. ParameterMinTypMaxUnit OPERATING CONDITIONS RF Frequency Range 71 76 GHz PERFORMANCE Gain 19 21.5 dB Gain Variation over Temperature 0.02 dB/°C Output Power for 1 dB Compression (P1dB) 22.5 25 dBm Saturated Output Power (P ) 26.5 dBm SAT Output Third-Order Intercept (OIP3) at Maximum Gain1 30 dBm Input Return Loss 12 dB Output Return Loss 12 dB POWER SUPPLY Total Supply Current (I )2 450 mA DD 1 Data taken at output power (POUT) = 12 dBm per tone, 1 MHz spacing. 2 Adjust VGGx from −2 V to 0 V to achieve the total drain current (IDD) = 450 mA. Rev. A | Page 3 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION TYPICAL APPLICATION CIRCUIT ASSEMBLY DIAGRAM MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GaAs MMICS HANDLING PRECAUTIONS Storage Cleanliness Static Sensitivity Transients General Handling MOUNTING Eutectic Die Attach Epoxy Die Attach WIRE BONDING OUTLINE DIMENSIONS ORDERING GUIDE
