Datasheet ADL5324 (Analog Devices)
Description400 MHz TO 4000 MHz ½ Watt RF Driver Amplifier
Pages / Page20 / 1 — 400 MHz to 4000 MHz. ½ Watt RF Driver Amplifier. Data Sheet. ADL5324. …
RevisionB
File Format / SizePDF / 553 Kb
400 MHz to 4000 MHz. ½ Watt RF Driver Amplifier. Data Sheet. ADL5324. FEATURES. FUNCTIONAL BLOCK DIAGRAM
Datasheet ADL5324 Analog Devices, Revision: B
400 MHz to 4000 MHz ½ Watt RF Driver Amplifier Data Sheet ADL5324 FEATURES FUNCTIONAL BLOCK DIAGRAM Operation from 400 MHz to 4000 MHz GND Gain of 14.6 dB at 2140 MHz (2) OIP3 of 43.1 dBm at 2140 MHz ADL5324 P1dB of 29.1 dBm at 2140 MHz Noise figure of 3.8 dB BIAS Dynamically adjustable bias 1 2 3
001
Adjustable power supply bias: 3.3 V to 5 V RFIN GND RFOUT
10562-
Low power supply current: 62 mA to 133 mA
Figure 1.
No bias resistor needed Operating temperature range of −40°C to +105°C SOT-89 package, MSL-1 rated ESD rating of ±3 kV (Class 2) APPLICATIONS Wireless infrastructure Automated test equipment ISM/AMR applications GENERAL DESCRIPTION
The ADL5324 incorporates a dynamically adjustable biasing The ADL5324 also delivers excel ent ACPR vs. output power and circuit that al ows for the customization of OIP3 and P1dB bias voltage. The driver can deliver greater than 17 dBm of output performance from 3.3 V to 5 V, without the need for an external power at 2140 MHz, while achieving an ACPR of −55 dBc at 5 V. If bias resistor. This feature gives the designer the ability to tailor the bias is reduced to 3.3 V, the −55 dBc ACPR output power driver amplifier performance to the specific needs of the design. only minimally reduces to 15 dBm. This feature also creates the opportunity for dynamic biasing of
–30
the driver amplifier where a variable supply is used to al ow for
–35
full 5 V biasing under large signal conditions, and then reduced
Bc) d –40
supply voltage when signal levels are smaller and lower power
( T E –45
consumption is desirable. This scalability reduces the need to
S F F –50
evaluate and inventory multiple driver amplifiers for different
R O E
output power requirements, from 25 dBm to 29 dBm output
–55 SOURCE
power levels.
–60 CARRI VCC = 3.3V Hz –65 VCC = 5V
The ADL5324 is also rated to operate across the wide temperature
5M –70
range of −40°C to +105°C for reliable performance in designs
R @
that experience higher temperatures, such as power amplifiers.
–75 ACP
The ½ W driver amplifier also covers the wide frequency range
–80
of 400 MHz to 4000 MHz, and only requires a few external
–85 –20 –15 –10 –5 0 5 10 15 20 25
components to be tuned to a specific band within that wide range.
POUT (dBm)
10562–055 This high performance broadband RF driver amplifier is wel Figure 2. ACPR vs. Output Power, Single Carrier W-CDMA, suited for a variety of wired and wireless applications, including TM1-64 at 2140 MHz cellular infrastructure, ISM band power amplifiers, defense equipment, and instrumentation equipment. A fully populated evaluation board is available.
Rev. B Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062−9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2012 Analog Devices, Inc. All rights reserved.
Document Outline Features Applications General Description Functional Block Diagram Table of Contents Revision History Specifications Typical Scattering Parameters Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics High Temperature Operation Applications Information Basic Layout Connections Soldering Information and Recommended PCB Land Pattern Matching Procedure W-CDMA ACPR Performance Evaluation Board Outline Dimensions Ordering Guide
