20 /10 — ADL5324. Data Sheet. ) m. OIP3 (dBm). , dB. –40°C. +25°C. dB ( 3. +85°C. …
Revision
B
PDF / 553 Kb
ADL5324. Data Sheet. ) m. OIP3 (dBm). , dB. –40°C. +25°C. dB ( 3. +85°C. , OIP. P1dB (dBm). dB 1. Bm). , P. B (. 3 (. , GA E R. GAIN (dB). FIGU. NF (dB). OIS
ADL5324Data Sheet503448) m453346OIP3 (dBm), dB40–40°C32+25°C44dB ( 3353142+85°C, OIP30P1dB (dBm)3040dB 1Bm)Bm)dd, P252938INB (3 (1d–40°CIP20P28+25°C36O, GA E R15GAIN (dB)2734+85°CFIGU102632ENF (dB)OIS52530N02428 033 25702590261026302650267026902570259026102630265026702690 036 FREQUENCY (MHz) 10562- FREQUENCY (MHz) 10562- Figure 16. Gain, P1dB, OIP3, and Noise Figure vs. Frequency, Figure 19. OIP3 and P1dB vs. Frequency and Temperature, 2570 MHz to 2690 MHz 2570 MHz to 2690 MHz 14.5502570MHz482630MHz–40°C2690MHz14.0464413.5+25°C42B) dBm)13.0dN (403 (AI GIP+85°CO3812.5363412.03211.530 037 2570259026102630265026702690 034 –505101520FREQUENCY (MHz) 10562- P 10562- OUT PER TONE (dBm) Figure 17. Gain vs. Frequency and Temperature, 2570 MHz to 2690 MHz Figure 20. OIP3 vs. POUT and Frequency, 2570 MHz to 2690 MHz 07–5–10S226) B)–15dBS (dS11(+85°CEERR–205MET AS12FIGURE+25°C–25OISS-PAN–304–40°C–35–4032570259026102630265026702690 035 038 2570259026102630265026702690FREQUENCY (MHz) 10562- 10562- FREQUENCY (MHz) Figure 18. Input Return Loss (S11), Output Return Loss (S22), and Reverse Figure 21. Noise Figure vs. Frequency and Temperature, Isolation (S12) vs. Frequency, 2570 MHz to 2690 MHz 2570 MHz to 2690 MHz Rev. B | Page 10 of 20 Document Outline Features Applications General Description Functional Block Diagram Table of Contents Revision History Specifications Typical Scattering Parameters Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics High Temperature Operation Applications Information Basic Layout Connections Soldering Information and Recommended PCB Land Pattern Matching Procedure W-CDMA ACPR Performance Evaluation Board Outline Dimensions Ordering Guide
