Datasheet ADL5324 (Analog Devices) - 8
Description400 MHz TO 4000 MHz ½ Watt RF Driver Amplifier
Pages / Page20 / 8 — ADL5324. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. OIP3 (dBm). , …
File Format / SizePDF / 553 Kb
ADL5324. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. OIP3 (dBm). , dB. +85°C. dB ( 3. +25°C. , OIP B. P1dB (dBm). –40°C. Bm). , P. B (. 3 ( IP
ADL5324 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS OIP3 (dBm) , dB +85°C dB ( 3 +25°C , OIP B P1dB (dBm) –40°C Bm) , P B ( 3 ( IP
ADL5324 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 50 35 50 ) OIP3 (dBm) m 45 34 48 , dB +85°C 40 33 46 dB ( 3 +25°C 35 32 44 , OIP B 30 P1dB (dBm) 31 42 D –40°C 1 Bm) Bm) d d , P 25 30 40 IN B ( 3 ( IP 20 1d P 29 38 O , GA GAIN (dB) E +25°C R 15 –40°C 28 36 FIGU 10 27 34 E NF (dB) +85°C OIS 5 26 32 N 0 25 30 869 884 900 915 930 946 961
015
018
FREQUENCY (MHz)
10562-
FREQUENCY (MHz)
10562- Figure 4. Gain, P1dB, OIP3, and Noise Figure vs. Frequency, Figure 7. OIP3 and P1dB vs. Frequency and Temperature, 869 MHz to 961 MHz 869 MHz to 961 MHz
17.5 55 –40°C 53 51 17.0 +25°C 49 47 B) d Bm) 16.5 d N ( 45 3 ( AI +85°C G IP O 43 41 16.0 39 869MHz 37 915MHz 961MHz 15.5 35 869 884 900 915 930 946 961
016
–5 0 5 10 15 20
019
FREQUENCY (MHz)
10562-
POUT PER TONE (dBm)
10562- Figure 5. Gain vs. Frequency and Temperature, 869 MHz to 961 MHz Figure 8. OIP3 vs. POUT and Frequency, 869 MHz to 961 MHz
0 7 –5 S22 +85°C –10 6 ) B ) –15 dB S (d ( +25°C E ER S11 R –20 5 MET A FIGU E R –40°C –25 OIS S-PA N S12 –30 4 –35 –40 3 869 884 900 915 930 946 961
017
020
FREQUENCY (MHz)
10562-
FREQUENCY (MHz)
10562- Figure 6. Input Return Loss (S11), Output Return Loss (S22), and Reverse Figure 9. Noise Figure vs. Frequency and Temperature, Isolation (S12) vs. Frequency, 869 MHz to 961 MHz 869 MHz to 961 MHz Rev. B | Page 8 of 20 Document Outline Features Applications General Description Functional Block Diagram Table of Contents Revision History Specifications Typical Scattering Parameters Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics High Temperature Operation Applications Information Basic Layout Connections Soldering Information and Recommended PCB Land Pattern Matching Procedure W-CDMA ACPR Performance Evaluation Board Outline Dimensions Ordering Guide
