Datasheet ADL5324 (Analog Devices) - 9
Description400 MHz TO 4000 MHz ½ Watt RF Driver Amplifier
Pages / Page20 / 9 — Data Sheet. ADL5324. ) m. OIP3 (dBm). +25°C. –40°C. , dB. dB ( 3. +85°C. …
File Format / SizePDF / 553 Kb
Data Sheet. ADL5324. ) m. OIP3 (dBm). +25°C. –40°C. , dB. dB ( 3. +85°C. , OIP. P1dB (dBm). dB 1. Bm). , P. B (. 3 (. 1d P. , GA E. GAIN (dB). FIGU. NF (dB). OIS
Data Sheet ADL5324 ) m OIP3 (dBm) +25°C –40°C , dB dB ( 3 +85°C , OIP P1dB (dBm) dB 1 Bm) , P B ( 3 ( 1d P , GA E GAIN (dB) FIGU NF (dB) OIS
Data Sheet ADL5324 50 35 48 ) m 45 OIP3 (dBm) 34 46 +25°C –40°C , dB 40 33 44 dB ( 3 35 32 +85°C 42 , OIP P1dB (dBm) 30 31 40 dB 1 Bm) Bm) d d , P 25 30 38 IN B ( –40°C 3 ( +25°C IP 20 1d P 29 36 O , GA E GAIN (dB) R 15 28 34 +85°C FIGU 10 27 32 E NF (dB) OIS 5 26 30 N 0 25 28 2110 2120 2130 2140 2150 2160 2170
027
030
FREQUENCY (MHz)
10562-
FREQUENCY (MHz)
10562- Figure 10. Gain, P1dB, OIP3, and Noise Figure vs. Frequency, Figure 13. OIP3 and P1dB vs. Frequency and Temperature, 2110 MHz to 2170 MHz 2110 MHz to 2170 MHz
16.0 50 2110MHz 48 2140MHz 15.5 2170MHz –40°C 46 44 15.0 42 B) +25°C d Bm) 14.5 d N ( 40 3 ( AI G IP O 38 +85°C 14.0 36 34 13.5 32 13.0 30 2110 2120 2130 2140 2150 2160 2170
028 031
–5 0 5 10 15 20 FREQUENCY (MHz)
10562-
P
10562-
OUT PER TONE (dBm)
Figure 11. Gain vs. Frequency and Temperature, 2110 MHz to 2170 MHz Figure 14. OIP3 vs. POUT and Frequency, 2110 MHz to 2170 MHz
0 6 –5 –10 S22 5 ) B ) +85°C –15 dB S (d S11 ( E ER R –20 4 +25°C MET A S12 FIGU R E –25 OIS S-PA N –40°C –30 3 –35 –40 2 2110 2120 2130 2140 2150 2160 2170
029 032
2110 2120 2130 2140 2150 2160 2170 FREQUENCY (MHz)
10562- 10562-
FREQUENCY (MHz)
Figure 12. Input Return Loss (S11), Output Return Loss (S22), and Reverse Figure 15. Noise Figure vs. Frequency and Temperature, Isolation (S12) vs. Frequency, 2110 MHz to 2170 MHz 2110 MHz to 2170 MHz Rev. B | Page 9 of 20 Document Outline Features Applications General Description Functional Block Diagram Table of Contents Revision History Specifications Typical Scattering Parameters Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics High Temperature Operation Applications Information Basic Layout Connections Soldering Information and Recommended PCB Land Pattern Matching Procedure W-CDMA ACPR Performance Evaluation Board Outline Dimensions Ordering Guide
