23 /10 — ADL5604. Data Sheet. OIP3 (dBm). +25°C. –40°C. , dB. P1dB (dBm). dB (. …
Revision
C
PDF / 672 Kb
ADL5604. Data Sheet. OIP3 (dBm). +25°C. –40°C. , dB. P1dB (dBm). dB (. +85°C. Bm). , OIP. B (. 3 (. 1d P. , P. GAIN (dB). , GA F. NF (dB). 1.93. 1.94. 1.95. 1.96
ADL5604Data Sheet453344OIP3 (dBm)40+25°C3243)–40°Cm35, dB314230P1dB (dBm)dB (+85°C3304125Bm)Bm)dd, OIPB (3 (dB20–40°C12940IP1d PO, PGAIN (dB)IN15+85°C+25°C2839, GA F10N27385NF (dB)026371.931.941.951.961.971.981.991.931.941.951.961.971.981.99 010 013 FREQUENCY (GHz)FREQUENCY (GHz) 08220- 08220- Figure 10. Gain, P1dB, OIP3 at POUT =14 dBm/Tone and Figure 13. OIP3 at POUT =14 dBm/Tone and P1dB vs. Frequency Noise Figure vs. Frequency and Temperature 18441.96GHz1.99GHz1743161.93GHz42–40°C15B)+25°C41dBm) d14N (+85°C3 (AIIP40GO133912381110371.931.941.951.961.971.981.99–10 –8–6–4–2024681012141618 011 014 FREQUENCY (GHz)POUT PER TONE (dBm) 08220- 08220- Figure 11. Gain vs. Frequency and Temperature Figure 14. OIP3 vs. POUT and Frequency 06–5S115)B)–10dS22(dB+85°C( ERSRE T–15E4FIGU+25°CEARAM P–20OIS NS-–40°C3S12–25–3021.931.941.951.961.971.981.99 012 1.931.941.951.961.971.981.99 015 FREQUENCY (GHz)FREQUENCY (GHz) 08220- 08220- Figure 12. Input Return Loss (S11), Output Return Loss (S22), and Reverse Figure 15. Noise Figure vs. Frequency and Temperature Isolation (S12) vs. Frequency Rev. C | Page 10 of 23 Document Outline Features Functional Block Diagram General Description Table of Contents Revision History Specifications Typical Scattering Parameters Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Applications Information Basic Layout Connections Power Supply RF Input Interface RF Output Interface Power-Down Circuit ADL5604 Match ACPR and EVM Thermal Considerations Soldering Information and Recommended PCB Land Pattern Evaluation Board Outline Dimensions Ordering Guide
