Datasheet HMC789ST89E (Analog Devices) - 4
DescriptionInGaP HBT GAIN BLOCK MMIC AMPLIFIER, 0.7 -2.8 GHz
Pages / Page16 / 4 — HMC789ST89E. InGaP HBT GAIN BLOCK MMIC. AMPLIFIER, 0.7 -2.8 GHz
File Format / SizePDF / 716 Kb
HMC789ST89E InGaP HBT GAIN BLOCK MMIC AMPLIFIER, 0.7 -2.8 GHz
HMC789ST89E
v02.0314
InGaP HBT GAIN BLOCK MMIC AMPLIFIER, 0.7 -2.8 GHz ACPR vs. Supply Voltage @ 880 MHz CDMA IS95, 9 Channels Forward
-20 -30 T CDMA IS95 -40 Frequency: 880 MHz 4.5V M Integration BW: 1.228 MHz Forward Link, 9 Channels 5V -50 (dBc) 5.5V -60 ACPR K - S -70 C -80 Source ACPR LO -90 0 2 4 6 8 10 12 14 16 18 20 22 CHANNEL POWER (dBm) IN B A
Broadband Gain & Return Loss @ 1900 MHz Gain vs. Temperature @ 1900 MHz
20 16 R & G E 10 14 IV (dB) S21 S11 R (dB) 0 S22 GAIN RESPONSE 12 +25 C -10 +85 C - 40 C S - D R -20 10 IE 1.2 1.4 1.6 1.8 2 2.2 2.4 2.6 1.7 1.8 1.9 2 2.1 FREQUENCY (GHz) FREQUENCY (GHz) LIF P
Input Return Loss vs. Output Return Loss vs.
M
Temperature @ 1900 MHz Temperature @ 1900 MHz
A 0 0 ) -4 -5 +25 C +25 C +85 C (dB (dB) +85 C S - 40 C - 40 C S LO -8 LOSS -10 N R U T E R RETURN -12 -15 -16 -20 1.7 1.8 1.9 2 2.1 1.7 1.8 1.9 2 2.1 FREQUENCY (GHz) FREQUENCY (GHz) I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com
4
Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte ho.c n o e m : 1-800-ANALOG-D
