Datasheet HMC789ST89E (Analog Devices) - 5
DescriptionInGaP HBT GAIN BLOCK MMIC AMPLIFIER, 0.7 -2.8 GHz
Pages / Page16 / 5 — HMC789ST89E. InGaP HBT GAIN BLOCK MMIC. AMPLIFIER, 0.7 -2.8 GHz. P1dB vs. …
File Format / SizePDF / 716 Kb
HMC789ST89E. InGaP HBT GAIN BLOCK MMIC. AMPLIFIER, 0.7 -2.8 GHz. P1dB vs. Temperature @ 1900 MHz
HMC789ST89E InGaP HBT GAIN BLOCK MMIC AMPLIFIER, 0.7 -2.8 GHz P1dB vs Temperature @ 1900 MHz
HMC789ST89E
v02.0314
InGaP HBT GAIN BLOCK MMIC AMPLIFIER, 0.7 -2.8 GHz P1dB vs. Temperature @ 1900 MHz Psat vs. Temperature @ 1900 MHz
28 30 T 27 29 M 26 28 (dBm) 25 (dBm) 27 K - S P1dB Psat C 24 +25 C +25 C +85 C 26 +85 C - 40 C - 40 C LO 23 25 22 24 1.7 1.8 1.9 2 2.1 1.7 1.8 1.9 2 2.1 IN B FREQUENCY (GHz) FREQUENCY (GHz) A
Output IP3 vs. Temperature @ 1900 MHz Output IP3 vs. Output Power @ 1900 MHz
R & G 50 50 E IV 45 45 R (dB) 40 (dB) 40 IP3 IP3 S - D 35 +25 C 35 +25 C R +85 C +85 C - 40 C - 40 C IE 30 30 1.7 1.8 1.9 2 2.1 0 2 4 6 8 10 12 14 16 18 LIF FREQUENCY (GHz) SINGLE TONE POUT (dBm) P M A
Reverse Isolation vs. Noise Figure vs. Temperature @ 1900 MHz Temperature @ 1900 MHz
8 -10 +25 C 6 +85 C +25 C - 40 C -15 +85 C ) - 40 C ) (dB N (dB 4 IO F -20 T N LA O IS 2 -25 0 -30 1.7 1.8 1.9 2 2.1 1.7 1.8 1.9 2 2.1 FREQUENCY (GHz) FREQUENCY (GHz) I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m
5
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte ho.c n o e m : 1-800-ANALOG-D
