Datasheet HMC789ST89E (Analog Devices) - 6
DescriptionInGaP HBT GAIN BLOCK MMIC AMPLIFIER, 0.7 -2.8 GHz
Pages / Page16 / 6 — HMC789ST89E. InGaP HBT GAIN BLOCK MMIC. AMPLIFIER, 0.7 -2.8 GHz. Gain, …
File Format / SizePDF / 716 Kb
HMC789ST89E. InGaP HBT GAIN BLOCK MMIC. AMPLIFIER, 0.7 -2.8 GHz. Gain, Power & IP3 vs. Supply Voltage @ 1900 MHz
HMC789ST89E InGaP HBT GAIN BLOCK MMIC AMPLIFIER, 0.7 -2.8 GHz Gain, Power & IP3 vs Supply Voltage @ 1900 MHz
HMC789ST89E
v02.0314
InGaP HBT GAIN BLOCK MMIC AMPLIFIER, 0.7 -2.8 GHz Gain, Power & IP3 vs. Supply Voltage @ 1900 MHz Power Compression @ 1900 MHz
50 50 ) m (%) 40 Pout T 3 (dB 40 Gain IP PAE PAE M ), O Gain m 30 B P1dB (dB), (d 30 OIP3 GAIN 20 P1dB K - S 20 (dB), (dBm), C 10 Pout GAIN LO 10 0 4.5 5 5.5 -1 3 7 11 15 19 SUPPLY VOLTAGE INPUT POWER (dBm) IN B A
ACPR vs. Supply Voltage @ 1960 MHz ACPR vs. Supply Voltage @ 2140 MHz CDMA 2000, 9 Channels Forward W-CDMA, 64 DPCH
-20 -20 R & G -30 -30 E CDMA 2000 W-CDMA -40 Frequency: 1960 MHz Integration BW: 1.228 MHz Frequency: 2140 MHz IV -40 Forward Link, 9 Channels Integration BW: 3.84 MHz 4.5V 64 DPCH 4.5V -50 R (dBc) 5V (dBc) 5V -50 5.5V 5.5V -60 ACPR ACPR -60 -70 S - D Source ACPR Source ACPR -80 -70 R -90 -80 IE 1 3 5 7 9 11 13 15 17 19 21 0 2 4 6 8 10 12 14 16 18 20 CHANNEL POWER (dBm) CHANNEL POWER (dBm) LIF P
Broadband Gain &
M
Return Loss @ 2600 MHz Gain vs. Temperature @ 2600 MHz
A 20 14 13 10 12 (dB) S21 S11 (dB) 0 S22 11 GAIN RESPONSE 10 +25 C -10 +85 C 9 - 40 C -20 8 2.2 2.3 2.4 2.5 2.6 2.7 2.8 2.9 2.3 2.4 2.5 2.6 2.7 2.8 FREQUENCY (GHz) FREQUENCY (GHz) I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com
6
Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte ho.c n o e m : 1-800-ANALOG-D
