Datasheet HMC634LC4 (Analog Devices)
DescriptionGaAs PHEMT MMIC DRIVER AMPLIFIER, 5 -20 GHz
Pages / Page8 / 1 — HMC634LC4. GaAs PHEMT MMIC DRIVER. AMPLIFIER, 5 - 20 GHz. Typical …
File Format / SizePDF / 434 Kb
HMC634LC4. GaAs PHEMT MMIC DRIVER. AMPLIFIER, 5 - 20 GHz. Typical Applications. Features. Functional Diagram. General Description
Datasheet HMC634LC4 Analog Devices
HMC634LC4
v03.0514
GaAs PHEMT MMIC DRIVER AMPLIFIER, 5 - 20 GHz Typical Applications Features
The HMC634LC4 is ideal for: Gain: 21 dB T • Point-to-Point Radios P1dB: +22 dBm M • Point-to-Multi-Point Radios & VSAT Saturated Power: +23 dBm @ 17% PAE • LO Driver for Mixers Single Supply Voltage: +5V @180 mA S - S • Military & Space 50 Ohm Matched Input/Output R 24 Lead 4x4mm SMT Package: 16mm2 IE LIF
P The HMC634LC4 is a GaAs PHEMT MMIC Driver M Amplifier in a leadless 4 x 4 mm ceramic surface mount package which operates between 5 and 20 K A GHz The amplifier provides up to 21 dB of gain, +29 C dBm Output IP3, and +22 dBm of output power at 1 dB gain compression, while requiring 180 mA from a +5V LO supply. The HMC634LC4 is an ideal driver amplifier for microwave radio applications from 5 to 20 GHz, IN B and may be biased at +5V, 130 mA to provide lower A gain with optimized PAE. The amplifier’s I/Os are DC blocked and matched to 50 Ohms with no external matching required. R & G E IV R D
Electrical Specifications, T = +25° C, Vdd = 5V, Idd= 180 mA [1] A 1-4
Parameter Min. Typ. Max. Min. Typ. Max. Units Frequency Range 5 - 16 16 - 20 GHz Gain 18 21 17 20 dB Gain Variation Over Temperature 0.025 0.035 0.020 0.030 dB/ °C Input Return Loss 18 14 dB Output Return Loss 14 13 dB Output Power for 1 dB Compression (P1dB) 19 22 16 20 dBm Saturated Output Power (Psat) 23 20.5 dBm Output Third Order Intercept (IP3) 29 28 dBm Noise Figure 7.5 7.5 dB Supply Current (Idd) (Idd = Idd + Idd + Idd + Idd ) 180 180 mA 1 2 3 4 [1] Adjust Vgg between -2 to 0V to achieve Idd= 180 mA Typical. I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m
1
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte ho.c n o e m : 1-800-ANALOG-D
