Datasheet HMC633LC4 (Analog Devices) - 3
DescriptionGaAs PHEMT MMIC DRIVER AMPLIFIER, 5.5 -17 GHz
Pages / Page8 / 3 — HMC633LC4. GaAs PHEMT MMIC DRIVER. AMPLIFIER, 5.5 - 17 GHz. Power …
File Format / SizePDF / 430 Kb
HMC633LC4. GaAs PHEMT MMIC DRIVER. AMPLIFIER, 5.5 - 17 GHz. Power Compression @ 11 GHz. Power Compression @ 17 GHz
HMC633LC4 GaAs PHEMT MMIC DRIVER AMPLIFIER, 5.5 - 17 GHz Power Compression @ 11 GHz Power Compression @ 17 GHz
HMC633LC4
v03.0514
35 35 T 30 (%) 30 (%) M PAE 25 PAE 25 Pout (dBm) Gain (dB) (dB), 20 (dB), 20 PAE (%) S - S GAIN 15 GAIN 15 R 10 (dBm), 10 (dBm), IE Pout 5 Pout (dBm) Gain (dB) Pout 5 PAE (%) LIF 0 0 P -20 -18 -16 -14 -12 -10 -8 -6 -4 -2 -20 -18 -16 -14 -12 -10 -8 -6 -4 -2 INPUT POWER (dBm) INPUT POWER (dBm) M K A
Output IP3 vs. Temperature Noise Figure vs. Temperature
C 36 16 LO 14 32 ) 12 (dB ) IN B 28 E 10 R U A (dBm IG 8 +25 C F IP3 24 +85 C E 6 -40 C IS O N 4 +25 C 20 +85 C 2 -40 C R & G E 16 0 2 4 6 8 10 12 14 16 18 20 4 6 8 10 12 14 16 18 IV FREQUENCY (GHz) FREQUENCY (GHz) R D
Gain & Power vs. Supply Voltage @ 11 GHz Reverse Isolation vs. Temperature
35 0 (dBm) 30 -20 ) Psat (dB Bm), N +25 C (d IO 25 -40 T +85 C -40 C LA P1dB O IS 20 -60 (dB), Gain P1dB Psat GAIN 15 -80 4.5 4.7 4.9 5.1 5.3 5.5 2 5 8 11 14 17 20 Vdd (V) FREQUENCY (GHz) I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m
3
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte ho.c n o e m : 1-800-ANALOG-D
