Datasheet HMC633LC4 (Analog Devices) - 6
DescriptionGaAs PHEMT MMIC DRIVER AMPLIFIER, 5.5 -17 GHz
Pages / Page8 / 6 — HMC633LC4. GaAs PHEMT MMIC DRIVER. AMPLIFIER, 5.5 - 17 GHz. Pin …
File Format / SizePDF / 430 Kb
HMC633LC4. GaAs PHEMT MMIC DRIVER. AMPLIFIER, 5.5 - 17 GHz. Pin Descriptions. Application Circuit
HMC633LC4 GaAs PHEMT MMIC DRIVER AMPLIFIER, 5.5 - 17 GHz Pin Descriptions Application Circuit
HMC633LC4
v03.0514
Pin Number Function Description Interface Schematic 1, 5 - 8, 11 - 14, No connection. These pins may be connected to DC/RF N/C T 18, 21, 23 ground. Performance will not be affected. M Package Bottom must 2, 4, 15, 17 GND be connected to RF/DC ground. This pin is AC coupled 3 RFIN S - S and matched to 50 Ohms. R IE Gate control for amplifier, please follow “MMIC Amplifier 9 Vgg Biasing Procedure” Application Note: See application circuit for required external components. LIF P This pin is AC coupled M 16 RFOUT and matched to 50 Ohms. K A 24, 22, Vdd1, Vdd2, Power Supply Voltage for the amplifier. See application C 20, 19 Vdd3, Vdd4 circuit for required external components. LO
Application Circuit
IN B A Component Value C1 - C5 100 pF C6 - C10 1000 pF C11 - C15 2.2 µF R & G E IV R D I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com
6
Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte ho.c n o e m : 1-800-ANALOG-D
