Datasheet HMC633 (Analog Devices) - 5
DescriptionGaAs PHEMT MMIC DRIVER AMPLIFIER, 5 -17 GHz
Pages / Page8 / 5 — HMC633. GaAs PHEMT MMIC DRIVER. AMPLIFIER, 5 - 17 GHz. Outline Drawing. …
File Format / SizePDF / 654 Kb
HMC633. GaAs PHEMT MMIC DRIVER. AMPLIFIER, 5 - 17 GHz. Outline Drawing. Die Packaging Information. 2 - 5
HMC633 GaAs PHEMT MMIC DRIVER AMPLIFIER, 5 - 17 GHz Outline Drawing Die Packaging Information 2 - 5
HMC633
v02.0517
2 IP H K - C C LO IN B A R & G E IV R NOTES: S - D 1. ALL DIMENSIONS ARE IN INCHES [MM] 2. DIE THICKNESS IS .004” R 3. TYPICAL BOND IS .004” SQUARE IE 4. BACKSIDE METALLIZATION: GOLD 5. BOND PAD METALLIZATION: GOLD 6. BACKSIDE METAL IS GROUND. LIF 7. CONNECTION NOT REQUIRED FOR UNLABELED BOND PADS. P M A
[1] Standard Alternate GP-2 (Gel Pack) [2] [1] Refer to the “Packaging Information” section for die packaging dimensions. [2] For alternate packaging information contact Hittite Microwave Corporation. For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
2 - 5
Phone: 781-329-4700 • Order online at www.analog.com Application Support: Phone: 1-800-ANALOG-D Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Performance Characteristics Broadband Gain & Return Loss Gain vs. Temperature Input Return Loss vs. Temperature Output Return Loss vs. Temperature P1dB vs. Temperature Psat vs. Temperature Power Compression @ 10 GHz Power Compression @ 17 GHz Output IP3 vs. Temperature @ Pin = -15 dBm Noise Figure vs. Temperature Gain & Power vs. Supply Voltage @ 10 GHz Reverse Isolation vs. Temperature Gain, Power & Output IP3 vs. Gate Voltage @ 10 GHz Absolute Maximum Ratings Typical Supply Current vs. Vdd Outline Drawing Die Packaging Information Pad Descriptions Assembly Diagram Mounting & Bonding Techniques for Millimeterwave GaAs MMICs Handling Precautions Mounting Wire Bonding
