Datasheet ADL5320 (Analog Devices) - 2
Description400 MHz TO 2700 MHz ¼ Watt RF Driver Amplifier
Pages / Page20 / 2 — ADL5320. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY 10/13—Rev. A to …
File Format / SizePDF / 919 Kb
ADL5320. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY 10/13—Rev. A to Rev. B. 6/12—Rev. 0 to Rev. A
ADL5320 Data Sheet TABLE OF CONTENTS REVISION HISTORY 10/13—Rev A to Rev B 6/12—Rev 0 to Rev A
link to page 1 link to page 1 link to page 1 link to page 1 link to page 2 link to page 3 link to page 4 link to page 5 link to page 5 link to page 5 link to page 6 link to page 7 link to page 11 link to page 12 link to page 12 link to page 13 link to page 13 link to page 14 link to page 15 link to page 15 link to page 16 link to page 18 link to page 18
Features .. 1 High Temperature and 3.3 V Operation ... 11 Applications ... 1 Applications Information .. 12 Functional Block Diagram .. 1 Basic Layout Connections ... 12 General Description ... 1 Soldering Information and Recommended PCB Revision History ... 2 Land Pattern .. 13 Specifications ... 3 Matching Procedure ... 14 Typical Scattering Parameters ... 4 Optimizing OP1dB .. 15 Absolute Maximum Ratings .. 5 W-CDMA ACPR Performance .. 15 Thermal Resistance .. 5 Evaluation Board .. 16 ESD Caution .. 5 Outline Dimensions ... 18 Pin Configuration and Function Descriptions ... 6 Ordering Guide .. 18 Typical Performance Characteristics ... 7
Changes to Operating Temperature Range Parameter, Changed 1805 MHz to 2110 MHz .. Throughout Table 3 ... 5 Changes to Figure 27 .. 10 Added Thermal Resistance Section and Table 4; Renumbered Changes to Figure 34 and Table 6 ... 12 Sequentially .. 5 Changes to Figure 35 .. 13 Added EPAD Notation to Figure 3 ... 6 Changes to Matching Procedures Section ... 14 Added Figure 27 ... 10 Added Optimizing OP1dB Section, Table 10, Table 11, Added High Temperature and 3.3 V Operation Section and Table 12, and Figure 39; Renumbered Sequentially ... 15 Figure 28 to Figure 33 .. 11 Changes to Evaluation Board Section ... 16 Added Applications Information Section and Figure 35 .. 12 Updated Outline Dimensions ... 18 Changes to Soldering Information and Recommended PCB Changes to Ordering Guide .. 18 Land Pattern .. 12 Changed −82 dBc to −80 dBc in W-CDMA ACPR Performance
Section .. 14 Changes to Features Section and General Description Section . ... .. 1 Added Figure 39 ... 14 Added Application Section and Figure 2; Renumbered Updated Outline Dimensions ... 17 Sequentially ... 1 Changes to Specifications Section .. 3
2/08—Revision 0: Initial Version
Deleted θJC (Junction to Paddle) Parameter, Table 3 .. 5 Rev. B | Page 2 of 20 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications Typical Scattering Parameters Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics High Temperature and 3.3 V Operation Applications Information Basic Layout Connections Soldering Information and Recommended PCB Land Pattern Matching Procedure Optimizing OP1dB W-CDMA ACPR Performance Evaluation Board Outline Dimensions Ordering Guide
