Data SheetADL53204039323835OIP3 (10dBm)OIP3 (–40°C))31m37OIP3 (+25°C)dB30( 336OIP3 (+85°C)3025P1dB, OIP3529dBBm)Bm)1dd20343 (P1dB (–40°C)B (); PIP281ddBO33P15P1dB (+25°C)F ( , N3227IN10GAINGA31P1dB (+85°C)526NF30 015 029 018 25 05840- 2500 2520 2540 2560 2580 2600 2620 2640 2660 2680 270025002550260026502700 05840- FREQUENCY (MHz)FREQUENCY (MHz) Figure 16. Gain, P1dB, OIP3, and Noise Figure vs. Frequency, Figure 19. OIP3 and P1dB vs. Frequency and Temperature, 2500 MHz to 2700 MHz 2500 MHz to 2700 MHz 15464414–40°C4213+25°C40B) dBm) d12N (382700MHz2600MHz3 (AI+85°CGIP O3611342500MHz1032 016 019 93025002550260026502700 05840- 05840- –3–11357911131517192123FREQUENCY (MHz)POUT (dBm) Figure 17. Gain vs. Frequency and Temperature, 2500 MHz to 2700 MHz Figure 20. OIP3 vs. POUT and Frequency, 2500 MHz to 2700 MHz –25.008.0–25.57.5–57.0–26.0–106.5–26.5S22B)+85°Cd6.0–15–27.022 (5.5B) dB)+25°CS11d–27.5–20(5.012 (AND SSNF–28.0B)S124.5–25d–40°C4.0–28.511 ( S–303.5–29.03.0–35–29.52.5 020 017 –30.0–402.0240024502500255026002650270027502800 05840- 240024502500255026002650270027502800 05840- FREQUENCY (MHz)FREQUENCY (MHz) Figure 18. Input Return Loss (S11), Output Return Loss (S22), and Reverse Figure 21. Noise Figure vs. Frequency and Temperature, Isolation (S12) vs. Frequency, 2500 MHz to 2700 MHz 2500 MHz to 2700 MHz Rev. B | Page 9 of 20 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications Typical Scattering Parameters Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics High Temperature and 3.3 V Operation Applications Information Basic Layout Connections Soldering Information and Recommended PCB Land Pattern Matching Procedure Optimizing OP1dB W-CDMA ACPR Performance Evaluation Board Outline Dimensions Ordering Guide
