Datasheet HMC-AUH256 (Analog Devices)
DescriptionGaAs HEMT MMIC DRIVER AMPLIFIER, 17.5 -41.0 GHz
Pages / Page6 / 1 — HMC-AUH256. GaAs HEMT MMIC DRIVER. AMPLIFIER, 17.5 - 41.0 GHz. Typical …
File Format / SizePDF / 425 Kb
HMC-AUH256. GaAs HEMT MMIC DRIVER. AMPLIFIER, 17.5 - 41.0 GHz. Typical Applications. Features. Functional Diagram
Datasheet HMC-AUH256 Analog Devices
HMC-AUH256
v01.0208
GaAs HEMT MMIC DRIVER AMPLIFIER, 17.5 - 41.0 GHz Typical Applications Features
2 This HMC-AUH256 is ideal for: Gain: 21 dB • Point-to-Point Radios P1dB Output Power: +20 dBm • Point-to-Multi-Point Radios Wideband Performance: 17.5 to 40 GHz IP • VSAT Supply Voltage: +5V @ 295 mA H • SATCOM Small Chip Size: 2.1 x 0.92 x 0.1 mm - C S R IE IF
L P The HMC-AUH256 is a GaAs MMIC HEMT four stage M Driver Amplifi er which covers the frequency range of 17.5 to 40 GHz. The chip can easily be integrated K A into Multi-Chip-Modules (MCMs) due to its small (1.93 mm2) size. The HMC-AUH256 offers 21 dB of gain OC and +20 dBm output power at 1 dB compression from a bias supply of +5V @ 295 mA. The HMC-AUH256 BL may also be used as a frequency doubler. Detail bias condition to achieve doubler operation. IN A & G R E IV
Electrical Specifi cations [1], T = +25°C
R
A Vdd1 = Vdd2 = Vdd3 = Vdd4 = 5V, Idd1 + Idd2 + Idd3 + Idd4 = 295mA [2]
D Parameter Min. Typ. Max. Units Frequency Range 17.5 - 41 GHz Gain 21 dB Input Return Loss 8 dB 20 - 30 GHz 15 dB Output Return Loss 30 - 45 GHz 8 dB Output Power for 1 dB Compression 20 dBm Saturated Output Power 23 dBm Output IP3 27 dBm Supply Current (Idd1 + Idd2 + Idd3 + Idd4) 295 mA [1] Unless otherwise indicated, all measurements are from probed die [2] Adjust Vgg1 = Vgg2 = Vgg3 = Vgg4 between -1V to +0.3V (Typ. -0.3V) to achieve Idd1 = 50 mA, Idd2 = 50 mA, Idd3 = 75 mA, Idd4 = 120 mA Information furnish F ed obr pri y Anal ce, de og Device li s vie s r beyli, a eve nd to pla d to be accura ce o te and rder reliabl s e , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 rights of third parties that may result from its use. Specifications subject to change without notice. No
2 - 66
20 Alpha Road, Chelmsford, MA 01824 Phone: 978 Phon - e 25 : 7 0 81--3 32 3 9 4 - 3 F 70 ax 0 • O : 978 rder on -li25 n 0 e a - t 33 ww 73 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. w.analog.com Order On Trademarks and registered trademarks are the property of their respective owners. -line at www.h A it p tpite.co licatio m n Support: Phone: 1-800-ANALOG-D
