Datasheet HMC609 (Analog Devices) - 3
DescriptionGaAs PHEMT MMIC LOW NOISE AMPLIFIER, 2 - 4 GHz
Pages / Page6 / 3 — HMC609. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 2 - 4 GHz. Power …
File Format / SizePDF / 337 Kb
HMC609. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 2 - 4 GHz. Power Compression @ 3 GHz. Output IP3 vs. Temperature
HMC609 GaAs PHEMT MMIC LOW NOISE AMPLIFIER, 2 - 4 GHz Power Compression @ 3 GHz Output IP3 vs Temperature
HMC609
v03.0210
1
Power Compression @ 3 GHz Output IP3 vs. Temperature
25 40 IP 39 H 20 38 37 15 36 35 E - C 10 34 OIP3 (dBm) IS 33 +25C Pout +85C 5 Gain 32 -55C PAE Pout (dBm), GAIN (dB), PAE (%) 31 0 30 W NO -10 -8 -6 -4 -2 0 2 4 6 2 2.25 2.5 2.75 3 3.25 3.5 3.75 4 INPUT POWER (dBm) FREQUENCY (GHz) O S - L
Noise Figure vs. Temperature Reverse Isolation vs. Temperature
R 10 0 IE -5 9 -10 IF 8 -15 L 7 +25C -20 +85C P +25C 6 -55C -25 +85C -55C GURE (dB) M 5 -30 -35 A 4 SE FI ISOLATION (dB) -40 3 NOI -45 2 -50 1 -55 0 -60 2 2.25 2.5 2.75 3 3.25 3.5 3.75 4 2 2.25 2.5 2.75 3 3.25 3.5 3.75 4 FREQUENCY (GHz) FREQUENCY (GHz) Inf F or o mar pr tion f ic ur e, de nished bliy ve An ralyo a g n De d to p vices is lbaelc ie e o ved trde o b r e s a : H ccuraittt e itae M nd reliicr abl ow e. H a o v we e C ver, noo rpo F roa r ti p o ri n c , e 2 , d0el A iv lepha R ry, and otad, C o plac h e e o lm rde s rsfo : rd, MA 01 Analog Devi 8 c 2 es 4 , Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 rights of third parties that may result from its use. Specifications subject to change without notice. No
1 - 110
Phone: 978-250-3343 Fax: 978-250-3373 O P rde hon r O e: 7 n 81 - - l3in 2 e a 9-47 t w 0 ww 0 • O . rd h e itt r o i nte lin .co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r app ation Su sp@ pohrtitti : P te ho .c ne om : 1-800-ANALOG-D
