HMC594LC3B v03.0514 GaAs PHEMT MMIC LOW NOISEAMPLIFIER, 2 - 4 GHzPower Compression @ 3 GHz, 6VPower Compression @ 3 GHz, 5V 25 25 T (%) Pout (%) Pout M 20 20 Gain Gain PAE PAE PAE PAE 15 15 (dB), (dB), E - S GAIN GAIN 10 10 IS (dBm), (dBm), O 5 5 Pout Pout 0 0 W N -10 -8 -6 -4 -2 0 2 4 6 8 10 12 14 16 -10 -8 -6 -4 -2 0 2 4 6 8 10 12 14 16 INPUT POWER (dBm) INPUT POWER (dBm) O S - L Output IP3 vs. Temperature [1]Reverse Isolation vs. Temperature [1] R 40 0 IE 38 -5 36 LIF 34 ) -10 (dB +25C P 32 N +85C (dBm) 30 -40C IO +25C -15 M T +85C LA OIP3 28 -40C A O IS -20 26 24 -25 22 20 -30 2 2.25 2.5 2.75 3 3.25 3.5 3.75 4 2 2.25 2.5 2.75 3 3.25 3.5 3.75 4 FREQUENCY (GHz) FREQUENCY (GHz) Gain, Power & OIP3Reverse Isolation vs. Temperature [1]vs. Supply Voltage @ 3 GHz ) 0 40 m dB 3 ( 35 -5 ), IP ) m 30 Gain P1dB -10 dB Psat (dB +25C N +85C 25 OIP3 sat ( IO -15 -40C T P ), LA 20 O IS -20 15 -25 10 (dB), P1dB (dBm -30 5 2 2.25 2.5 2.75 3 3.25 3.5 3.75 4 4.5 5 5.5 6 6.5 GAIN FREQUENCY (GHz) Vdd SUPPLY VOLTAGE (V) [1] Typical response for 5V and 6V Vdd Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m 3 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
