Datasheet HMC451LP3, 451LP3E (Analog Devices)
DescriptionGaAs PHEMT MMIC MEDIUM POWER AMPLIFIER, 5 - 18 GHz
Pages / Page6 / 1 — HMC451LP3 / 451LP3E. GaAs PHEMT MMIC MEDIUM. POWER AMPLIFIER, 5 - 18 GHz. …
HMC451LP3 / 451LP3E. GaAs PHEMT MMIC MEDIUM. POWER AMPLIFIER, 5 - 18 GHz. Typical Applications. Features. Functional Diagram
Datasheet HMC451LP3, 451LP3E Analog Devices
HMC451LP3 / 451LP3E
v01.0118
GaAs PHEMT MMIC MEDIUM POWER AMPLIFIER, 5 - 18 GHz Typical Applications Features
The HmC451lp3(e) is ideal for: Gain: 18 dB T • microwave radio & VsAT saturated power: +21 dBm @ 18% pAe m • military & space output ip3: +28 dBm s • Test equipment & sensors single supply: +5V @ 120 mA r - • fiber optics 50 ohm matched input/output e • lo Driver for HmC mixers 16 lead 3x3mm smT package: 9mm² w o p
The HmC451lp3(e) is an efficient GaAs pHemT r & mmiC medium power Amplifier housed in a leadless A roHs compliant smT package. operating between e 5 and 18 GHz, the amplifier provides 18 dB of gain, +21 dBm of saturated power and 18% pAe from a lin single +5V supply. This 50 ohm matched amplifier does not require any external components and the s - rf i/o’s are DC blocked, making it an ideal linear r gain block or lo driver for HmC mixers. The HmC451lp3(e) eliminates the need for wire bonding, ie and al ows the use of surface mount manufacturing techniques. lif p m A
Electrical Specifications, T = +25° C, Vdd = Vdd = +5V A 1 2
parameter min. Typ. max. min. Typ. max. Units frequency range 5 - 16 16 - 18 GHz Gain 15 18 12.5 16 dB Gain Variation over Temperature 0.02 0.03 0.02 0.03 dB/ °C input return loss 13 13 dB output return loss 12 8 dB output power for 1 dB 16.5 19.5 16 19 dBm Compression (p1dB) saturated output power (psat) 21 20 dBm output Third order intercept (ip3) 28 25 dBm noise figure 7 7 dB supply Current (idd) 120 150 120 150 mA Information furnished by Analog Devices is believed to be accurate and reliable. However, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
1
rights of third parties that may result from its use. Specifications subject to change without notice. No Phone: 781-329-4700 • Order online at www.analog.com license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Trademarks and registered trademarks are the property of their respective owners. Application Support: Phone: 1-800-ANALOG-D
