Datasheet HMC451LP3, 451LP3E (Analog Devices) - 4
DescriptionGaAs PHEMT MMIC MEDIUM POWER AMPLIFIER, 5 - 18 GHz
Pages / Page6 / 4 — HMC451LP3 / 451LP3E. GaAs PHEMT MMIC MEDIUM. POWER AMPLIFIER, 5 - 18 GHz. …
HMC451LP3 / 451LP3E. GaAs PHEMT MMIC MEDIUM. POWER AMPLIFIER, 5 - 18 GHz. Absolute Maximum Ratings
HMC451LP3 / 451LP3E GaAs PHEMT MMIC MEDIUM POWER AMPLIFIER, 5 - 18 GHz Absolute Maximum Ratings
HMC451LP3 / 451LP3E
v01.0118
GaAs PHEMT MMIC MEDIUM POWER AMPLIFIER, 5 - 18 GHz Absolute Maximum Ratings Typical Supply Current vs. Vdd = Vdd 1 2
Drain Bias Voltage (Vdd = Vdd ) +5.5V Vdd = Vdd (V) idd + idd (mA) 1 2 1 2 1 2 rf input power (rfin)(Vdd = +5Vdc) +10 dBm +4.5 120 Channel Temperature 175 °C +5.0 122 T Continuous pdiss (T = 85 °C) +5.5 124 m 1.15 w (derate 12.8 mw/°C above 85 °C) note: Amplifier will operate over full voltage range shown above s Thermal resistance 78 °C/w (channel to ground paddle) r - storage Temperature -65 to +150 °C eleCTrosTATiC sensiTiVe DeViCe e operating Temperature -40 to +85 °C oBserVe HAnDlinG preCAUTions esD sensitivity (HBm) Class 1A, passed 250V w
16-Lead Lead Frame Chip Scale Package [LFCSP]
o
3 x 3 mm Body and 0.85 mm Package Height
p
(HCP-16-1) Outline Drawing Dimensions shown in millimeters
r &
DETAIL A (JEDEC 95)
A
3.10 0.30 3.00 SQ
e
0.25 PIN 1 2.90 0.20 INDICATOR PIN 1 13 16 INDICATOR AREA OPTIONS (SEE DETAIL A)
lin
0.50 12 1 BSC EXPOSED 1.95 PAD
s -
1.70 SQ 1.50
r
9 4
ie
0.45 8 5 0.20 MIN TOP VIEW BOTTOM VIEW 0.40 0.35
lif
0.90 FOR PROPER CONNECTION OF
p
0.85 THE EXPOSED PAD, REFER TO 0.05 MAX THE PIN CONFIGURATION AND
m
0.80 0.02 NOM FUNCTION DESCRIPTIONS SECTION OF THIS DATA SHEET.
A
COPLANARITY SEATING 0.08 PLANE 0.20 REF PKG-004863 COMPLIANT WITH JEDEC STANDARDS MO-220-VEED-4. 03-15-2017-B
16-lead lead frame chip scale package [lfCsp] 3 mm × 3 mm Body and 0.85 mm package Height (HCp-16-1) Dimensions shown in mil imeters.
Package Information
part number package Body material lead finish msl rating package marking [3] HmC451lp3 low stress injection molded plastic sn/pb solder msl1 [1] 451 XXXX HmC451lp3e roHs-compliant low stress injection molded plastic 100% matte sn msl1 [2] 451 XXXX [1] max peak reflow temperature of 235 °C [2] max peak reflow temperature of 260 °C [3] 4-Digit lot number XXXX For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com Application Support: Phone: 1-800-ANALOG-D
4
