Datasheet HMC499LC4 (Analog Devices)
DescriptionSMT PHEMT MEDIUM POWER AMPLIFIER 21 - 32 GHz
Pages / Page6 / 1 — HMC499LC4. SMT PHEMT MEDIUM POWER AMPLIFIER. 21 - 32 GHz. Typical …
HMC499LC4. SMT PHEMT MEDIUM POWER AMPLIFIER. 21 - 32 GHz. Typical Applications. Features. Functional Diagram. General Description
Datasheet HMC499LC4 Analog Devices
HMC499LC4
v06.0418
SMT PHEMT MEDIUM POWER AMPLIFIER 21 - 32 GHz Typical Applications Features
The HmC499lC4 is ideal for: output ip3: +34 dBm T • point-to-point radios saturated power: +24 dBm @ 16% pAe m s • point-to-multi-point radios & VsAT Gain: 17 dB • Test equipment & sensors supply: +5V @ 200mA r - • military end-Use 50 ohm matched input/output e roHs Compliant 4x4 mm smT package w o p
The HmC499lC4 is a high dynamic range GaAs r & pHemT mmiC medium power Amplifier housed in a A leadless “pb free” roHs Compliant smT package. e operating from 21 to 32 GHz, the amplifier provides 16 dB of gain, +24 dBm of saturated power and 16% lin pAe from a +5V supply voltage. The rf i/os are DC blocked and matched to 50 ohms for ease of s - use. The HmC499lC4 eliminates the need for wire r bonding, al owing use of surface mount manufacturing techniques. ie lif p m A
Electrical Specifications, T = +25° C, Vdd1, 2, 3 = 5V, Idd = 200 mA* A
parameter min. Typ. max. min. Typ. max. min. Typ. max. Units frequency range 21 - 24 24 - 28 28 - 32 GHz Gain 14 17 13 16 9 13 dB Gain Variation over Temperature 0.02 0.03 0.02 0.03 0.02 0.03 dB/ °C input return loss 10 8 8 dB output return loss 11 12 8 dB output power for 1 dB Compression (p1dB) 20 23 20 23 20 23 dBm saturated output power (psat) 23.5 23.5 24 dBm output Third order intercept (ip3) 31 34 33.5 dBm noise figure 6 5 5 dB supply Current 200 200 200 mA (idd)(Vdd = +5V, Vgg = -0.8V Typ.) * Adjust Vgg between -2 to 0V to achieve Idd = 200 mA typical. Information furnished by Analog Devices is believed to be accurate and reliable. However, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
1
rights of third parties that may result from its use. Specifications subject to change without notice. No Phone: 781-329-4700 • Order online at www.analog.com license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Trademarks and registered trademarks are the property of their respective owners. Application Support: Phone: 1-800-ANALOG-D Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Performance Characteristics Broadband Gain & Return Loss Gain vs. Temperature Input Return Loss vs. Temperature Output Return Loss vs. Temperature P1dB vs. Temperature Psat vs. Temperature Output IP3 vs. Temperature Noise Figure vs. Temperature Gain, Power & Output IP3 vs. Supply Voltage @ 22 GHz Reverse Isolation vs. Temperature Power Compression @ 22 GHz Power Compression @ 30 GHz Absolute Maximum Ratings Typical Supply Current vs. Vdd Outline Drawing Pin Descriptions Application Circuit Evaluation PCB List of Material for Evaluation PCB
