Datasheet HMC499LC4 (Analog Devices) - 4
DescriptionSMT PHEMT MEDIUM POWER AMPLIFIER 21 - 32 GHz
Pages / Page6 / 4 — HMC499LC4. SMT PHEMT MEDIUM POWER AMPLIFIER. 21 - 32 GHz. Absolute …
HMC499LC4. SMT PHEMT MEDIUM POWER AMPLIFIER. 21 - 32 GHz. Absolute Maximum Ratings. Typical Supply Current vs. Vdd. 24-T
HMC499LC4 SMT PHEMT MEDIUM POWER AMPLIFIER 21 - 32 GHz Absolute Maximum Ratings Typical Supply Current vs Vdd 24-T
HMC499LC4
v06.0418
SMT PHEMT MEDIUM POWER AMPLIFIER 21 - 32 GHz Absolute Maximum Ratings Typical Supply Current vs. Vdd
Drain Bias Voltage (Vdd1, Vdd2, Vdd3) +5.5 Vdc Vdd (Vdc) idd (mA) Gate Bias Voltage (Vgg) -4 to 0 Vdc +4.5 193 T rf input power (rfin)(Vdd = +5 Vdc) +20 dBm +5.0 200 m Channel Temperature 175 °C +5.5 207 s Continuous pdiss (T= 85 °C) 2.25 w (derate 25 mw/°C above 85 °C) Note: Amplifier will operate over full voltage ranges shown above. Vgg adjusted to achieve Idd= 200 mA at +5V. Thermal resistance r - 40 °C/w (channel to ground paddle) e storage Temperature -65 to +150 °C eleCTrosTATiC sensiTiVe DeViCe w operating Temperature -40 to +85 °C
24-T
oBse
erminal Ceramic Leadless Chip Carrier [LCC]
rVe HAnDlinG preCAUTions o
(E-24-1) Dimensions shown in millimeters.
p
Outline Drawing
r &
4.05 0.36 3.90 SQ
A
0.30 PIN 1 3.75 0.08 0.24
e
INDICATOR BSC PIN 1 19 24 18 1 0.50
lin
BSC 2.60 EXPOSED PAD 2.50 SQ 2.40
s -
13 6
r
12 7 TOP VIEW 0.32 BOTTOM VIEW BSC
ie
2.50 REF 1.00 3.10 BSC 0.90 SIDE VIEW
lif
0.80 FOR PROPER CONNECTION OF THE EXPOSED PAD, REFER TO
p
THE PIN CONFIGURATION AND SEATING FUNCTION DESCRIPTIONS
m
PLANE SECTION OF THIS DATA SHEET.
A
PKG-004840 02-27-2017-B
24-Terminal Ceramic leadless Chip Carrier [lCC] (e-24-1) Dimensions shown in millimeters.
Package Information
part number package Body material lead finish msl rating package marking [2] HmC499lC4 Alumina, white Gold over nickel msl3 [1] H499 XXXX [1] max peak reflow temperature of 260 °C [2] 4-Digit lot number XXXX For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com Application Support: Phone: 1-800-ANALOG-D
4
Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Performance Characteristics Broadband Gain & Return Loss Gain vs. Temperature Input Return Loss vs. Temperature Output Return Loss vs. Temperature P1dB vs. Temperature Psat vs. Temperature Output IP3 vs. Temperature Noise Figure vs. Temperature Gain, Power & Output IP3 vs. Supply Voltage @ 22 GHz Reverse Isolation vs. Temperature Power Compression @ 22 GHz Power Compression @ 30 GHz Absolute Maximum Ratings Typical Supply Current vs. Vdd Outline Drawing Pin Descriptions Application Circuit Evaluation PCB List of Material for Evaluation PCB
