Datasheet HMC498 (Analog Devices)
DescriptionGaAs pHEMT MMIC POWER AMPLIFIER, 17 - 24 GHz
Pages / Page6 / 1 — HMC498. GaAs pHEMT MMIC. POWER AMPLIFIER, 17 - 24 GHz. Typical …
File Format / SizePDF / 402 Kb
HMC498. GaAs pHEMT MMIC. POWER AMPLIFIER, 17 - 24 GHz. Typical Applications. Features. Functional Diagram. General Description
Datasheet HMC498 Analog Devices
HMC498
v03.0713
GaAs pHEMT MMIC POWER AMPLIFIER, 17 - 24 GHz Typical Applications Features
The HMC498 is ideal for: Output IP3: +34 dBm IP • Point-to-Point Radios Saturated Power: +27 dBm @ 25% PAE H • Point-to-Multi-Point Radios Gain: 24 dB • VSAT Supply Voltage: +5V • Military & Space 50 Ohm Matched Input/Output S - C R Die Size: 2.38 x 1.46 x 0.1 mm IE LIF
P The HMC498 is a high dynamic range GaAs pHEMT M MMIC Power Amplifier which operates between 17 and 24 GHz. The HMC498 provides 24 dB of gain, R A +27 dBm of saturated power and 25% PAE from E a +5V supply voltage. The HMC498 amplifier can W easily be integrated into Multi-Chip-Modules (MCMs) O due to its small size. All data is with the chip in a 50 Ohm test fixture connected via 0.025mm (1 mil) diameter wire bonds of minimal length 0.31mm (12 mils). R & P A E IN L
Electrical Specifications, T = +25° C, Vdd = 5V, Idd = 250mA* A
Parameter Min. Typ. Max. Min. Typ. Max. Min. Typ. Max. Units Frequency Range 17 - 19 19 - 22 22 - 24 GHz Gain 20 23 28 21 24 28 20 23 28 dB Gain Variation Over Temperature 0.03 0.04 0.03 0.04 0.03 0.04 dB/ °C Input Return Loss 11 11 8 dB Output Return Loss 20 18 15 dB Output Power for 1 dB Compression (P1dB) 20 23.5 22 25 21 24 dBm Saturated Output Power (Psat) 27 26.5 25.5 dBm Output Third Order Intercept (IP3) 34 34 34 dBm Noise Figure 3.5 4.0 4.5 dB Supply Current (Idd)(Vdd = 5V, Vgg = -0.8V Typ.) 250 275 250 275 250 275 mA * Adjust Vgg between -2 to 0V to achieve Idd = 250mA typical. Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m
1
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
