HMC442LC3B v03.0514 GaAs PHEMT MMIC MEDIUMPOWER AMPLIFIER, 17.5 - 25.5 GHzPower Compression @ 18 GHzPower Compression @ 23 GHz 28 28 T 24 (%) 24 Pout (%) M Pout Gain Gain PAE 20 PAE PAE 20 PAE (dB), 16 (dB), 16 S - S GAIN 12 GAIN 12 R 8 (dBm), 8 (dBm), IE Pout 4 Pout 4 LIF 0 0 P -10 -6 -2 2 6 10 14 -10 -6 -2 2 6 10 14 INPUT POWER (dBm) INPUT POWER (dBm) M R A Output IP3 vs. TemperatureNoise Figure vs. Temperature E 34 12 W O 10 30 ) (dB 8 26 E R (dBm) U IG 6 R & P F Psat 22 E A IS 4 O N E +25C 18 +85C +25C -40C 2 +85C -40C LIN 14 0 16 17 18 19 20 21 22 23 24 25 26 27 16 17 18 19 20 21 22 23 24 25 26 27 FREQUENCY (GHz) FREQUENCY (GHz) Gain, Power and Output IP3 vs. Supply Voltage @ 23 GHzReverse Isolation vs. Temperature 30 0 (dBm) 25 IP3 -10 20 ) (dBm), -20 (dB +25C N Psat +85C 15 IO -30 -40C T LA (dBm), 10 O IS -40 GAIN P1dB 5 P1dB Psat -50 IP3 (dB), 0 -60 GAIN 4.5 5 5.5 16 17 18 19 20 21 22 23 24 25 26 27 Vdd Supply Voltage (Vdc) FREQUENCY (GHz) Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m 3 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
