Datasheet HMC442 (Analog Devices) - 3
DescriptionGaAs pHEMT MMIC MEDIUM POWER AMPLIFIERS, 17.5 - 25.5 GHz
Pages / Page6 / 3 — HMC442. GaAs pHEMT MMIC MEDIUM. POWER AMPLIFIERS, 17.5 - 25.5 GHz. Power …
File Format / SizePDF / 374 Kb
HMC442. GaAs pHEMT MMIC MEDIUM. POWER AMPLIFIERS, 17.5 - 25.5 GHz. Power Compression @ 21 GHz. Power Compression @ 25 GHz
HMC442 GaAs pHEMT MMIC MEDIUM POWER AMPLIFIERS, 17.5 - 25.5 GHz Power Compression @ 21 GHz Power Compression @ 25 GHz
HMC442
v04.0913
28 35 ) IP % 24 % 30 ( E E H A A 20 25 ), P ), P B B d d ( 16 ( 20 IN IN A A 12 15 ), G ), G S - C m m B B d 8 d 10 R t ( t ( u u o o P 4 P 5 IE 0 0 -10 -6 -2 2 6 10 14 -10 -6 -2 2 6 10 14 LIF INPUT POWER (dBm) INPUT POWER (dBm) P Pout (dBm) Gain (dB) PAE (%) Pout (dBm) Gain (dB) PAE (%) M R A
Output IP3 vs. Temperature Noise Figure vs. Temperature
E 34 10 W 30 8 O ) B d ( ) E 26 m 6 R U (dB IG 3 F IP 22 E 4 IS R & P O N A 18 2 E 14 0 16 17 18 19 20 21 22 23 24 25 26 27 16 17 18 19 20 21 22 23 24 25 26 LIN FREQUENCY (GHz) FREQUENCY (GHz) +25 C +85 C -55 C +25 C +85 C -55 C
Gain & Power vs. Supply Voltage @ 25 GHz Reverse Isolation vs. Temperature
26 0 ) m 24 B d -10 t ( a 22 s ) B ), P -20 20 d m ( B N d ( 18 IO -30 B T d A 1 L 16 O ), P IS -40 B d 14 ( IN A -50 12 G 10 -60 2.7 3.1 3.5 3.9 4.3 4.7 5.1 5.5 16 17 18 19 20 21 22 23 24 25 26 27 Vdd Supply Voltage (Vdc) FREQUENCY (GHz) Gain P1dB Psat +25 C +85 C -55 C Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m
3
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
