Datasheet HMC441LM1 (Analog Devices) - 5
DescriptionGaAs PHEMT MMIC MEDIUM POWER AMPLIFIER, 7 - 15.5 GHz
Pages / Page9 / 5 — HMC441LM1. GaAs PHEMT MMIC MEDIUM. POWER AMPLIFIER, 7 - 15.5 GHz. …
RevisionD
HMC441LM1. GaAs PHEMT MMIC MEDIUM. POWER AMPLIFIER, 7 - 15.5 GHz. Absolute Maximum Ratings. Typical Supply Current vs. Vdd
HMC441LM1 GaAs PHEMT MMIC MEDIUM POWER AMPLIFIER, 7 - 15.5 GHz Absolute Maximum Ratings Typical Supply Current vs Vdd
HMC441LM1
v04.1019
GaAs PHEMT MMIC MEDIUM POWER AMPLIFIER, 7 - 15.5 GHz Absolute Maximum Ratings Typical Supply Current vs. Vdd
Drain Bias Voltage (Vdd) +5.5 V Vdd (V) Idd (mA) T Gate Bias Voltage (Vgg1,Vgg2) -8 to 0V +5.5 92 M RF Input Power (RFIN) (Vdd = +5 Vdc) +15 dBm +5.0 90 Channel Temperature 175 °C +4.5 88 Continuous Pdiss (T = 85 °C) +3.3 83 0.67 W S - S (derate 7.5 mW/°C above 85 °C) +3.0 82 R Thermal Resistance 133 °C/W Note: Amplifier will operate over full voltage range shown above (channel to ground paddle) IE Storage Temperature -65 to +150 °C Operating Temperature -40 to +85 °C LIF P M ELECTROSTATIC SENSITIVE DEVICE OBSERVE HANDLING PRECAUTIONS
8-Terminal Chip Array Small Outline No Lead Cavity [LGA_CAV]
R A
5.08 x 5.08 mm Body and 1.01 mm Package Height
E
(CE-8-1) Dimensions shown in millimeters
W
Outline Drawing
O
5.21 0.56 5.08 SQ 0.46 1.00 PIN 1 4.95 BSC 0.36 INDICATOR AREA 2.67 3 1 DETAIL A
R & P
2.54 2.41
A
4 EXPOSED 8 PAD 0.61
E
0.51 0.41 1.47 5 7 TOP VIEW 1.37 BOTTOM VIEW
LIN
1.27 1.14 1.01 SIDE VIEW 0.25 REF 0.88 SEATING 1.83 1.65 PLANE 1.73 1.55 1.63 1.45 1.45 1.35 0.81 1.25 0.71 DETAIL A 0.61 PKG-000000 10-04-2017-B
8-Terminal Chip Array Small Outline No Lead Cavity [LGA_CAV] 5.08 mm × 5.08 mm Body and 1.01 mm Package Height (CE-8-1) Dimensions shown im millimeters
Package Information
Part Number Package Body Material Lead Finish Package Marking [1] H441 HMC441LM1 Plastic Gold plated XXXX H441 HMC441LM1TR Plastic Gold plated XXXX [1] 4-Digit lot number XXXX For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com
5
Application Support: Phone: 1-800-ANALOG-D
