Datasheet HMC415LP3, 415LP3E (Analog Devices) - 7
DescriptionGaAs InGaP HBT MMIC POWER AMPLIFIER, 4.9 - 5.9 GHz
Pages / Page8 / 7 — HMC415LP3 / 415LP3E. GaAs InGaP HBT MMIC. POWER AMPLIFIER, 4.9 - 5.9 GHz. …
File Format / SizePDF / 420 Kb
HMC415LP3 / 415LP3E. GaAs InGaP HBT MMIC. POWER AMPLIFIER, 4.9 - 5.9 GHz. Evaluation PCB
HMC415LP3 / 415LP3E GaAs InGaP HBT MMIC POWER AMPLIFIER, 4.9 - 5.9 GHz Evaluation PCB
HMC415LP3 / 415LP3E
v03.0605
11 T - SM S R IE IF L P M R A E W O & P R A
List of Materials for Evaluation PCB 105173 [1]
E The circuit board used in the fi nal application should Item Description IN use RF circuit design techniques. Signal lines J1 - J2 PCB Mount SMA RF Connector L should have 50 ohm impedance while the package J3 2 mm DC Header ground leads and exposed paddle should be con- C1 - C3 330 pF Capacitor, 0603 Pkg. nected directly to the ground plane similar to that C4 2.2 μF Capacitor, Tantalum shown. A sufficient number of via holes should be C5 0.5 pF Capacitor, 0603 Pkg. used to connect the top and bottom ground planes. C6 7.0 pF Capacitor, 0402 Pkg. The evaluation board should be mounted to an L1 3.0 nH Inductor, 0805 Pkg. appropriate heat sink. The evaluation circuit board U1 HMC415LP3 / HMC415LP3E Amplifi er shown is available from Hittite upon request. PCB [2] 104723 Eval Board [1] Reference this number when ordering complete evaluation PCB [2] Circuit Board Material: Rogers 4350 Information furnish F e o d r pri by An ce, de alog Devic leis vie s rbyeli, a eve nd to pla d to be accur ce o ate an r d der relia s ble , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. : 978 Phon -e25 : 7 0 81 -3 3 3 29 4 - 3 F 470 ax 0 • O : 978 rder o - nl 25 in 0 e a - t 33 ww 73
11 - 72
w.analog.com Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptipte.co licatio m n Support: Phone: 1-800-ANALOG-D
