18 /9 — Data Sheet. ADL5545. 4 GHz TO 6 GHz FREQUENCY BAND. ) m. , dB. OIP3. dB …
Revision
B
PDF / 373 Kb
Data Sheet. ADL5545. 4 GHz TO 6 GHz FREQUENCY BAND. ) m. , dB. OIP3. dB (. 5800MHz. , OIP. dB 1. Bm) d. , P. 3 (. GAIN. 5000MHz. IP O. , GA. E R. P1dB. FIGU
Data SheetADL55454 GHz TO 6 GHz FREQUENCY BAND4040) m35, dBOIP335dB (305800MHz3, OIP2530dB 1Bm) d, P20IN3 (GAIN5000MHzIP O25, GA15E RP1dB10FIGU20ENOISE FIGURE5OIS N0154.04.24.44.64.85.05.25.45.65.86.0 015 –5.0–2.502.55.0 018 FREQUENCY (GHz) 1385- 1 POUT PER TONE (dBm) 11385- Figure 15. Noise Figure, Gain, P1dB, and OIP3 vs. Frequency, Figure 18. OIP3 vs. Output Power (POUT) and Frequency, High Frequency Configuration High Frequency Configuration 20019–5–40°CS1118+25°C)–10BS2217S (dB)–15dER16N ( AIMETGA–20R15+85°C+105°CS-PA–2514S12–301312–354.04.24.44.64.85.05.25.45.65.86.0 016 4.04.24.44.64.85.05.25.45.65.86.0 019 FREQUENCY (GHz) 1385- FREQUENCY (GHz) 1 11385- Figure 16. Gain vs. Frequency and Temperature, Figure 19. Input Return Loss (S11), Output Return Loss (S22), and Reverse High Frequency Configuration Isolation (S12) vs. Frequency, High Frequency Configuration 40407.0+25°C35356.53030+85°C6.0–40°C+105°C)+105°C2525dB5.5( EBm)Bm)R+85°Cdd20205.0B (3 (FIGU1d+25°CIPE+25°CPO15154.5–40°COIS N–40°C10104.0+85°C55+105°C3.5003.04.04.24.44.64.85.05.25.45.65.86.0 017 4.04.24.44.64.85.05.25.45.65.86.0 020 FREQUENCY (GHz) 1385- 1 FREQUENCY (GHz) 1385- 1 Figure 17. P1dB and OIP3 vs. Frequency and Temperature, Figure 20. Noise Figure vs. Frequency and Temperature, High Frequency Configuration High Frequency Configuration Rev. B | Page 9 of 18 Document Outline FEATURES FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS 500 MHz TO 4 GHz FREQUENCY BAND 100 MHz TO 500 MHz FREQUENCY BAND 4 GHz TO 6 GHz FREQUENCY BAND GENERAL APPLICATIONS INFORMATION BASIC CONNECTIONS SOLDERING INFORMATION AND RECOMMENDED PCB LAND PATTERN OPERATION DOWN TO 30 MHz W-CDMA ACPR PERFORMANCE EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE NOTES NOTES
