Datasheet ADL5545 (Analog Devices) - 8
Description30 MHz to 6 GHz RF/IF Gain Block
Pages / Page18 / 8 — ADL5545. Data Sheet. 100 MHz TO 500 MHz FREQUENCY BAND. ) m. , dB. OIP3. …
File Format / SizePDF / 373 Kb
ADL5545. Data Sheet. 100 MHz TO 500 MHz FREQUENCY BAND. ) m. , dB. OIP3. dB (. GAIN. , OIP. 140MHz. dB 1. Bm). , P. 3 (. P1dB. IP O. 350MHz. , GA. E R. FIGU
ADL5545 Data Sheet 100 MHz TO 500 MHz FREQUENCY BAND ) m , dB OIP3 dB ( GAIN , OIP 140MHz dB 1 Bm) , P 3 ( P1dB IP O 350MHz , GA E R FIGU
ADL5545 Data Sheet 100 MHz TO 500 MHz FREQUENCY BAND 40 45 ) m 35 , dB OIP3 40 dB ( 30 3 GAIN , OIP 25 35 140MHz dB 1 Bm) , P 20 d IN 3 ( P1dB IP O 30 350MHz , GA 15 E R 10 FIGU 25 E 5 NOISE FIGURE OIS N 0 20 0.10 0.15 0.20 0.25 0.30 0.35 0.40 0.45 0.50
009
–5.0 –2.5 0 2.5 5.0
012
FREQUENCY (GHz)
1385- 1
POUT PER TONE (dBm)
1385- 1 Figure 9. Noise Figure, Gain, P1dB, and OIP3 vs. Frequency, Figure 12. OIP3 vs. Output Power (POUT) and Frequency, Low Frequency Configuration Low Frequency Configuration
26.0 0 25.5 –5 –40°C +25°C 25.0 ) –10 B 24.5 S (d B) –15 d ER 24.0 N ( AI MET S11 G +85°C A –20 R 23.5 +105°C S22 S-PA –25 23.0 S12 22.5 –30 22.0 –35 0.10 0.15 0.20 0.25 0.30 0.35 0.40 0.45 0.50
010
013
FREQUENCY (GHz)
1385- 1
FREQUENCY (GHz)
11385- Figure 10. Gain vs. Frequency and Temperature, Figure 13. Input Return Loss (S11), Output Return Loss (S22), and Reverse Low Frequency Configuration Isolation (S12) vs. Frequency, Low Frequency Configuration
40 40 6.0 +25°C –40°C +85°C 5.5 35 35 5.0 ) 30 30 dB 4.5 ( E Bm) +105°C Bm) R +85°C d d 25 25 4.0 +105°C B ( 3 ( FIGU 1d IP E P O 3.5 20 20 OIS +25°C N +25°C +85°C 3.0 –40°C 15 15 2.5 +105°C –40°C 10 10 2.0
1 1
0
014
FREQUENCY (GHz)
1385- 1
FREQUENCY (GHz)
11385- Figure 11. P1dB and OIP3 vs. Frequency and Temperature, Figure 14. Noise Figure vs. Frequency and Temperature, Low Frequency Configuration Low Frequency Configuration Rev. B | Page 8 of 18 Document Outline FEATURES FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS 500 MHz TO 4 GHz FREQUENCY BAND 100 MHz TO 500 MHz FREQUENCY BAND 4 GHz TO 6 GHz FREQUENCY BAND GENERAL APPLICATIONS INFORMATION BASIC CONNECTIONS SOLDERING INFORMATION AND RECOMMENDED PCB LAND PATTERN OPERATION DOWN TO 30 MHz W-CDMA ACPR PERFORMANCE EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE NOTES NOTES
