Datasheet ADL5545 (Analog Devices) - 7
Description30 MHz to 6 GHz RF/IF Gain Block
Pages / Page18 / 7 — Data Sheet. ADL5545. TYPICAL PERFORMANCE CHARACTERISTICS 500 MHz TO 4 GHz …
RevisionB
File Format / SizePDF / 373 Kb
Data Sheet. ADL5545. TYPICAL PERFORMANCE CHARACTERISTICS 500 MHz TO 4 GHz FREQUENCY BAND. ) m. 700MHz. , dB. 900MHz. OIP3. dB (. , OIP
Data Sheet ADL5545 TYPICAL PERFORMANCE CHARACTERISTICS 500 MHz TO 4 GHz FREQUENCY BAND ) m 700MHz , dB 900MHz OIP3 dB ( , OIP
Data Sheet ADL5545 TYPICAL PERFORMANCE CHARACTERISTICS 500 MHz TO 4 GHz FREQUENCY BAND 40 45 ) m 700MHz 35 , dB 900MHz OIP3 40 dB ( 30 3 , OIP 25 2140MHz 35 dB 1 GAIN Bm) d , P 20 IN 3 ( 2600MHz 1900MHz P1dB IP O 30 , GA 15 E R 10 4000MHz FIGU 25 E 5 NOISE FIGURE 3500MHz OIS N 0 20 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0
003
–5.0 –2.5 0 2.5 5.0
006
FREQUENCY (GHz)
1385- 1
POUT PER TONE (dBm)
1385- 1 Figure 3. Noise Figure, Gain, P1dB, and OIP3 vs. Frequency Figure 6. OIP3 vs. Output Power (POUT) and Frequency
25 0 –40°C 24 –5 +25°C 23 22 ) –10 B 21 S (d B) –15 d +85°C ER S11 S22 20 N ( AI MET G +105°C A –20 19 R 18 S-PA –25 S12 17 –30 16 15 –35 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0
004
007
FREQUENCY (GHz)
1385- 1
FREQUENCY (GHz)
11385- Figure 4. Gain vs. Frequency and Temperature Figure 7. Input Return Loss (S11), Output Return Loss (S22), and Reverse Isolation (S12) vs. Frequency
40 40 6.0 +25°C –40°C 5.5 35 35 5.0 ) +85°C 30 30 dB 4.5 ( E +105°C Bm) +85°C Bm) R d d 25 25 4.0 B ( 3 ( +105°C FIGU 1d IP E +25°C P O 3.5 20 20 OIS +25°C N 3.0 +85°C +105°C –40°C 15 15 2.5 –40°C 10 10 2.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0
005
008
FREQUENCY (GHz)
11385-
FREQUENCY (GHz)
11385- Figure 5. P1dB and OIP3 vs. Frequency and Temperature Figure 8. Noise Figure vs. Frequency and Temperature Rev. B | Page 7 of 18 Document Outline FEATURES FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS 500 MHz TO 4 GHz FREQUENCY BAND 100 MHz TO 500 MHz FREQUENCY BAND 4 GHz TO 6 GHz FREQUENCY BAND GENERAL APPLICATIONS INFORMATION BASIC CONNECTIONS SOLDERING INFORMATION AND RECOMMENDED PCB LAND PATTERN OPERATION DOWN TO 30 MHz W-CDMA ACPR PERFORMANCE EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE NOTES NOTES
