Datasheet ADL8104 (Analog Devices)
Description | Wideband, High Linearity, Low Noise Amplifier, 0.4 GHz to 7.5 GHz |
Pages / Page | 23 / 1 — Wideband, High Linearity,. Low Noise Amplifier, 0.4 GHz to 7.5 GHz. Data … |
File Format / Size | PDF / 625 Kb |
Wideband, High Linearity,. Low Noise Amplifier, 0.4 GHz to 7.5 GHz. Data Sheet. ADL8104. FEATURES. FUNCTIONAL BLOCK DIAGRAM
link to page 23 link to page 23 link to page 23
Wideband, High Linearity, Low Noise Amplifier, 0.4 GHz to 7.5 GHz Data Sheet ADL8104 FEATURES FUNCTIONAL BLOCK DIAGRAM Single positive supply (self biased) AS BI DD High OIP2: 52 dBm typical at 0.6 GHz to 7.5 GHz NC R V NC 16 15 14 13 High gain: 15 dB typical at 0.6 GHz to 6 GHz High OIP3: 32 dBm typical GND 1 12 NC Low noise figure: 3.5 dB typical at 0.4 GHz to 6 GHz RF 2 11 IN RFOUT RoHS-compliant, 3 mm × 3 mm, 16-lead LFCSP NC 3 10 GND APPLICATIONS NC 4 9 NC Test instrumentation 5 6 7 8
001
Military communications NC NC NC NC
23884- Figure 1.
GENERAL DESCRIPTION
The ADL8104 is a gallium arsenide (GaAs), monolithic high output second-order intercept (OIP2) of 52 dBm typical at microwave integrated circuit (MMIC), pseudomorphic high 0.6 GHz to 6 GHz, making the ADL8104 suitable for military electron mobility transistor (pHEMT), low noise, wideband, and test instrumentation applications. high linearity amplifier that operates from 0.4 GHz to 7.5 GHz. The ADL8104 also features inputs and outputs that are The ADL8104 provides a typical gain of 15 dB at 0.6 GHz to internal y matched to 50 Ω. The RFIN and RFOUT pins are 6 GHz, a 3.5 dB typical noise figure at 0.4 GHz to 6 GHz, a internal y ac-coupled and the bias inductor is also integrated, 20 dBm typical output power for 1 dB compression (OP1dB) at making the ADL8104 ideal for surface-mounted technology 0.6 GHz to 6 GHz, and a typical output third-order intercept (SMT)-based, high density applications. (OIP3) of 32 dBm at 0.6 GHz to 6 GHz, requiring only 150 mA The ADL8104 is housed in an RoHS-compliant, 3 mm × 3 mm, from a 5 V drain supply voltage. The low noise amplifier has a 16-lead LFCSP.
Rev. 0 Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. No license is granted by implication or otherwise under any patent or patent rights of Analog Tel: 781.329.4700 ©2020 Analog Devices, Inc. All rights reserved. Devices. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications 0.4 GHz to 0.6 GHz Frequency Range 0.6 GHz to 6 GHz Frequency Range 6 GHz to 7.5 GHz Frequency Range DC Specifications Absolute Maximum Ratings Thermal Resistance Electrostatic Discharge (ESD) Ratings ESD Ratings for ADL8104 ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Theory of Operation Applications Information Recommended Bias Sequencing Outline Dimensions Ordering Guide
