Datasheet HMC8412CHIPS (Analog Devices) - 8
DescriptionLow Noise Amplifier, 0.4 GHz to 10 GHz
Pages / Page21 / 8 — HMC8412CHIPS. Data Sheet. 18kΩ, IDQ = 20mA. 3.5kΩ, IDQ = 40mA. 1.43kΩ, …
File Format / SizePDF / 489 Kb
HMC8412CHIPS. Data Sheet. 18kΩ, IDQ = 20mA. 3.5kΩ, IDQ = 40mA. 1.43kΩ, IDQ = 60mA. 604Ω, IDQ = 80mA. –10. URN L. –15. 3.5kΩ, I. DQ = 40mA
HMC8412CHIPS Data Sheet 18kΩ, IDQ = 20mA 3.5kΩ, IDQ = 40mA 1.43kΩ, IDQ = 60mA 604Ω, IDQ = 80mA –10 URN L –15 3.5kΩ, I DQ = 40mA
HMC8412CHIPS Data Sheet 0 0 18kΩ, IDQ = 20mA 3.5kΩ, IDQ = 40mA 1.43kΩ, IDQ = 60mA –5 –5 604Ω, IDQ = 80mA B) B) d d ( ( S S S S O –10 O –10 URN L URN L T 18kΩ, IDQ = 20mA T –15 3.5kΩ, I –15 RE DQ = 40mA 1.43kΩ, I RE DQ = 60mA UT 604Ω, IDQ = 80mA UT INP INP –20 –20 –25 –25 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0
019
0 1 2 3 4 5 6 7 8 9 10 11
022
FREQUENCY (GHz)
24012-
FREQUENCY (GHz)
24012- Figure 19. Input Return Loss vs. Frequency for Various Supply Currents, Figure 22. Input Return Loss vs. Frequency for Various Supply Currents, VDD = 5 V 200 MHz to 1 GHz, VDD = 5 V
0 0 +85°C +25°C –55°C –5 –5 B) B) d d ( ( S S S S O O –10 –10 URN L URN L T T RE –15 RE –15 UT +85°C UT P +25°C P UT –55°C UT O O –20 –20 –25 –25 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0
020
023
FREQUENCY (GHz)
24012-
FREQUENCY (GHz)
24012- Figure 20. Output Return Loss vs. Frequency for Various Temperatures, Figure 23. Output Return Loss vs. Frequency for Various Temperatures, 200 MHz to 1 GHz, VDD = 5 V, IDQ = 60 mA VDD = 5 V, IDQ = 60 mA
0 0 7V 6V 5V –5 –5 4V B) B) 3V d d ( ( S S S S O O –10 –10 URN L URN L T T RE –15 RE –15 UT 7V UT P P 6V UT 5V UT O O –20 4V –20 3V –25 –25 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0
021
024
FREQUENCY (GHz)
24012-
FREQUENCY (GHz)
24012- Figure 21. Output Return Loss vs. Frequency for Various Supply Voltages, Figure 24. Output Return Loss vs. Frequency for Various Supply Voltages, 200 MHz to 1 GHz, IDQ = 60 mA IDQ = 60 mA Rev. 0 | Page 8 of 21 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications 0.4 GHz to 8 GHz Frequency Range 8 GHz to 10 GHz Frequency Range Absolute Maximum Ratings Thermal Resistance Electrostatic Discharge (ESD) Ratings ESD Ratings for HMC8412CHIPS ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Small Signal Response Large Signal Response Theory of Operation Applications Information Typical Application Circuit Recommended Bias Sequencing During Power-Up During Power-Down Assembly Diagram Mounting and Bonding Techniques for Millimeter Wave GaAs MMICs Handling Precautions Outline Dimensions Ordering Guide
