Datasheet HMC8412CHIPS (Analog Devices) - 9
DescriptionLow Noise Amplifier, 0.4 GHz to 10 GHz
Pages / Page21 / 9 — Data Sheet. HMC8412CHIPS. 18kΩ, IDQ = 20mA. 18kΩ, I. 3.5kΩ, I. DQ = 20mA. …
File Format / SizePDF / 489 Kb
Data Sheet. HMC8412CHIPS. 18kΩ, IDQ = 20mA. 18kΩ, I. 3.5kΩ, I. DQ = 20mA. DQ = 40mA. 1.43kΩ, I. DQ = 60mA. 1.43kΩ, IDQ = 60mA
Data Sheet HMC8412CHIPS 18kΩ, IDQ = 20mA 18kΩ, I 3.5kΩ, I DQ = 20mA DQ = 40mA 1.43kΩ, I DQ = 60mA 1.43kΩ, IDQ = 60mA
Data Sheet HMC8412CHIPS 0 0 18kΩ, IDQ = 20mA 18kΩ, I 3.5kΩ, I DQ = 20mA DQ = 40mA 3.5kΩ, I 1.43kΩ, I DQ = 40mA DQ = 60mA 1.43kΩ, IDQ = 60mA –5 604Ω, IDQ = 80mA –5 604Ω, IDQ = 80mA B) B) d d ( ( S S S S O O –10 –10 URN L URN L T T RE –15 RE –15 UT UT P P UT UT O O –20 –20 –25 –25 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0
025
0 1 2 3 4 5 6 7 8 9 10 11
028
FREQUENCY (GHz)
24012-
FREQUENCY (GHz)
24012- Figure 25. Output Return Loss vs. Frequency for Various Supply Currents, Figure 28. Output Return Loss vs. Frequency for Various Supply Currents, VDD = 5 V 200 MHz to 1 GHz, VDD = 5 V
4.0 4.0 +85°C +85°C +25°C 3.5 +25°C 3.5 –55°C –55°C 3.0 3.0 ) ) dB dB ( 2.5 ( 2.5 E E R R 2.0 2.0 FIGU FIGU E E 1.5 1.5 OIS OIS N N 1.0 1.0 0.5 0.5 0 0 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0
026
029
FREQUENCY (GHz)
24012-
FREQUENCY (GHz)
24012- Figure 26. Noise Figure vs. Frequency for Various Temperatures, 200 MHz to Figure 29. Noise Figure vs. Frequency for Various Temperatures, 1 GHz, VDD = 5 V, IDQ = 60 mA VDD = 5 V, IDQ = 60 mA
4.0 4.0 7V 7V 3.5 6V 3.5 6V 5V 5V 4V 4V 3.0 3V 3.0 3V ) ) dB dB ( 2.5 ( 2.5 E E R R 2.0 2.0 FIGU FIGU E E 1.5 1.5 OIS OIS N N 1.0 1.0 0.5 0.5 0 0 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0
027
030
FREQUENCY (GHz)
24012-
FREQUENCY (GHz)
24012- Figure 27. Noise Figure vs. Frequency for Various Supply Voltages, 200 MHz Figure 30. Noise Figure vs. Frequency for Various Supply Voltages, IDQ = 60 mA to 1 GHz, IDQ = 60 mA Rev. 0 | Page 9 of 21 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications 0.4 GHz to 8 GHz Frequency Range 8 GHz to 10 GHz Frequency Range Absolute Maximum Ratings Thermal Resistance Electrostatic Discharge (ESD) Ratings ESD Ratings for HMC8412CHIPS ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Small Signal Response Large Signal Response Theory of Operation Applications Information Typical Application Circuit Recommended Bias Sequencing During Power-Up During Power-Down Assembly Diagram Mounting and Bonding Techniques for Millimeter Wave GaAs MMICs Handling Precautions Outline Dimensions Ordering Guide
