Datasheet HMC8412TCPZ-EP (Analog Devices) - 3
DescriptionpHEMT 0.4 GHz TO 11 GHz LOW NOISE AMPLIFIER
Pages / Page13 / 3 — DLA LAND AND MARITIME. COLUMBUS, OHIO. 16236. V62/21602
File Format / SizePDF / 224 Kb
DLA LAND AND MARITIME COLUMBUS, OHIO 16236 V62/21602
1.3 Absolute maximum ratings. 1/ Supply voltage (VDD) ... +7 V RF input power ... 25 dBm Continuous power dissipation (PD) : TCASE = +85C .. 0.82 W TCASE = +125C .. 0.46 W Storage temperature range (TSTG) .. -65C to +125C Peak reflow (moisture sensitivity level 1 (MSL1)) ... +260C Junction temperature (TJ) to maintain 1,000,000 hours mean time to failure (MTTF) ... +175C Nominal junction temperature (TA = +125C, VDD = 5 V, IDQ = 60 mA) .. +157.8C Thermal resistance, junction to case (JC) .. 109.3C/W Electrostatic discharge (ESD) rating: Human body model (HDM) per JEDEC JS-001 ... 500 V 1.4 Recommended operating conditions. 2/ Supply voltage (VDD) ... +5 V Operating temperature range (TA) ... -55C to +125C 1/ Stresses beyond those listed under “absolute maximum rating” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. 2/ Use of this product beyond the manufacturers design rules or stated parameters is done at the user’s risk. The manufacturer and/or distributor maintain no responsibility or liability for product used beyond the stated limits.
SIZE CODE IDENT NO. DWG NO.
COLUMBUS, OHIO A 16236 V62/21602
REV PAGE 3
