HMC7950Data Sheet18 GHz TO 28 GHz FREQUENCY RANGE TA = 25°C, VDD = 5 V, VGG2 = open, unless otherwise stated. When using VGG2, it is recommended to limit VGG2 from −2 V to +2.6 V. POUT is output power. Table 3. ParameterSymbolTest Conditions/CommentsMinTypMaxUnit FREQUENCY RANGE 18 28 GHz GAIN 13 16.5 dB Gain Variation over Temperature 0.012 dB/°C RETURN LOSS Input 19 dB Output 16 dB OUTPUT Output Power for 1 dB Compression P1dB 10 14.5 dBm Saturated Output Power PSAT 17 dBm Output Third-Order Intercept IP3 Measurement taken at POUT/tone = 4 dBm 24 dBm NOISE FIGURE NF 2.8 5 dB DC SPECIFICATIONSTable 4. ParameterSymbolTest Conditions/CommentsMinTypMaxUnit SUPPLY CURRENT Total Supply Current IDD 64 100 mA Total Supply Current vs. VDD IDD = 58 mA 3 V IDD = 61 mA 4 V IDD = 64 mA 5 V IDD = 66 mA 6 V IDD = 69 mA 7 V SUPPLY VOLTAGE VDD 3 5 7 V VGG2 PIN VGG2 Normal condition is VGG2 = open −2.0 2.6 V Rev. A | Page 4 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS 2 GHz TO 5 GHz FREQUENCY RANGE 5 GHz TO 18 GHz FREQUENCY RANGE 18 GHz TO 28 GHz FREQUENCY RANGE DC SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION EVALUATION BOARD EVALUATION BOARD SCHEMATIC OUTLINE DIMENSIONS ORDERING GUIDE
