Datasheet HMC392A (Analog Devices)
DescriptionGaAs MMIC LOW NOISE AMPLIFIER, 3.5 - 7.0 GHz
Pages / Page6 / 1 — HMC392A. GaAs MMIC LOW NOISE. AMPLIFIER, 3.5 - 7.0 GHz. Typical …
File Format / SizePDF / 530 Kb
HMC392A. GaAs MMIC LOW NOISE. AMPLIFIER, 3.5 - 7.0 GHz. Typical Applications. Features. Functional Diagram. General Description
Datasheet HMC392A Analog Devices
HMC392A
v02.0618
GaAs MMIC LOW NOISE AMPLIFIER, 3.5 - 7.0 GHz Typical Applications Features
The HMC392A is ideal for: Gain: 17.2 dB IP • Point-to-Point Radios Noise Figure: 1.7 dB H • VSAT Single Supply Voltage: +5V • LO Driver for HMC Mixers 50 Ohm Matched Input/Output E - C • Military EW, ECM, C3I No External Components Required IS • Space Small Size: 1.3 x 1.0 x 0.1 mm O
W N The HMC392A is a GaAs MMIC Low Noise Amplifier O die which operates between 3.5 and 7.0 GHz. The amplifier provides 17.2 dB of gain, 1.7 dB noise figure, and 32.5 dBm IP3 from a +5V supply voltage. The R - L HMC392A has six bonding adjustment options which IE al ow the user to select the bias point and output power of the device (+10 to +19.7 dBm). The HMC392A LIF amplifier can easily be integrated into Multi-Chip- P Modules (MCMs) due to its small (1.3 mm2) size. All M data is with the chip in a 50 Ohm test fixture connected A via 0.025mm (1 mil) diameter wire bonds of minimal length 0.31mm (12 mils).
Electrical Specifications, T = +25° C, Vdd = 5V A
Parameter Min. Typ. Max. Min. Typ. Max. Units Frequency Range 4.0 - 6.0 3.5 - 7.0 GHz Gain 14.5 17.4 14.5 17.2 dB Gain Variation Over Temperature 0.005 0.005 dB/ °C Noise Figure 1.7 3.0 1.7 3.4 dB Input Return Loss 12 12 dB Output Return Loss 20 18 dB Output Power for 1 dB Compression (P1dB) 19.5 19 dBm Saturated Output Power (Psat) 20.5 20 dBm Output Third Order Intercept (IP3) 32.5 32.5 dBm Supply Current (Idd) 59 75 59 75 mA Note: Data taken with pad PS2 bonded to ground (state 2) unless otherwise noted. Information furnished by Analog Devices is believed to be accurate and reliable. However, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
1
rights of third parties that may result from its use. Specifications subject to change without notice. No Phone: 781-329-4700 • Order online at www.analog.com license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Trademarks and registered trademarks are the property of their respective owners. Application Support: Phone: 1-800-ANALOG-D
