Datasheet HMC717ALP3E (Analog Devices) - 4
DescriptionGaAs pHEMT MMIC LOW NOISE AMPLIFIER, 4.8 - 6.0 GHz
Pages / Page11 / 4 — HMC717ALP3E. Gaas pHEMT MMIC LOW NOIsE. aMpLIFIER, 4.8 - 6.0 GHz. power …
HMC717ALP3E. Gaas pHEMT MMIC LOW NOIsE. aMpLIFIER, 4.8 - 6.0 GHz. power Compression @ 4800 MHz [1]
HMC717ALP3E Gaas pHEMT MMIC LOW NOIsE aMpLIFIER, 4.8 - 6.0 GHz power Compression @ 4800 MHz [1]
HMC717ALP3E
v09.0816
Gaas pHEMT MMIC LOW NOIsE aMpLIFIER, 4.8 - 6.0 GHz power Compression @ 4800 MHz [1] power Compression @ 4800 MHz [2]
25 25 ) 20 % 20 % ( E E T A A 15 15 ), P ), P B B M d 10 d ( 10 IN IN A A 5 5 ), G ), G m m B B d 0 d 0 t ( E - S t ( u u o o P -5 P -5 IS -10 -10 O -20 -16 -12 -8 -4 0 4 8 -20 -16 -12 -8 -4 0 4 8 INPUT POWER (dBm) INPUT POWER (dBm) Pout Gain PAE Pout Gain PAE W N O
power Compression @ 5900 MHz [1] power Compression @ 5900 MHz [2]
25 25 R - L ) 20 % 20 % ( IE E E A 15 A 15 ), P ), P B B d 10 d ( 10 ( LIF IN IN A A P 5 5 ), G ), G m m B B M d 0 d 0 t ( t ( u u A o o P -5 P -5 -10 -10 -20 -16 -12 -8 -4 0 4 8 -20 -16 -12 -8 -4 0 4 8 INPUT POWER (dBm) INPUT POWER (dBm) Pout Gain PAE Pout Gain PAE
Gain, power & Noise Figure Gain, power & Noise Figure vs. supply Voltage @ 4800 MHz [3] vs. supply Voltage @ 5900 MHz [3]
22 1.6 22 1.7 20 1.5 20 1.6 ) m 18 1.4 N m 1.5 N O 18 O (dB IS (dB IS E E 16 1.3 16 1.4 1dB F F IG 1dB IG P P U U ) & 14 1.2 R ) & 14 1.3 R E E (dB ( (dB ( n d d 12 1.1 B n 1.2 B ai 12 ) ai ) G G 10 1 10 1.1 8 0.9 8 1 2.7 3 3.3 3.6 3.9 4.2 4.5 4.8 5.1 5.4 2.7 3 3.3 3.6 3.9 4.2 4.5 4.8 5.1 5.4 Voltage Supply (V) Voltage Supply (V) P1dB NF P1dB NF Gain Gain [1] Vdd = 5V, Rbias = 825Ω [2] Vdd = 3V, Rbias = 5.76kΩ [3] Rbias = 825Ω for Vdd = 5V, Rbias = 5.76kΩ for Vdd = 3V For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com Application Support: Phone: 1-800-ANALOG-D
4
Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Gain, Noise Figure & Rbias @ 5900 MHz Output IP3 vs. Rbias @ 5900 MHz Gain, Noise Figure & Rbias @ 4800 MHz Output IP3 vs. Rbias @ 4800 MHz Gain, Power & Noise Figure vs. Supply Voltage @ 5900 MHz Gain, Power & Noise Figure vs. Supply Voltage @ 4800 MHz Power Compression @ 5900 MHz Power Compression @ 5900 MHz Power Compression @ 4800 MHz Output IP3 and Total Supply Current vs. Supply Voltage @ 5900 MHz Output IP3 and Total Supply Current vs. Supply Voltage @ 4800 MHz Output IP3 vs. Temperature Psat vs. Temperature P1dB vs. Temperature Noise Figure vs. Temperature Reverse Isolation vs. Temperature Output Return Loss vs. Temperature Input Return Loss vs. Temperature Gain vs. Temperature Gain vs. Temperature Broadband Gain & Return Loss Power Compression @ 4800 MHz Absolute Bias Resistor Range & Recommended Bias Resistor Values Absolute Maximum Ratings Typical Supply Current vs. Supply Voltage Outline Drawing Package Information Pin Descriptions Application Circuit Evaluation PCB List of Materials
