HMC717ALP3E v09.0816 Gaas pHEMT MMIC LOW NOIsEaMpLIFIER, 4.8 - 6.0 GHzOutput Ip3 vs. Rbias @ 4800 MHzGain, Noise Figure & Rbias @ 4800 MHz 34 20 2.2 T 32 17 2 M 30 N O 14 1.8 ) 28 IS ) m E B d F (dB 26 ( 11 1.6 IG 3 IN U A R E - S IP 24 G E 8 1.4 ( d B IS 22 ) 5 1.2 O 20 18 2 1 100 1000 10000 100 1000 10000 Rbias (Ohms) Rbias (Ohms) W N Vdd=3V Vdd=5V Vdd=3V Vdd=5V O Output Ip3 vs. Rbias @ 5900 MHzGain, Noise Figure & Rbias @ 5900 MHz R - L 35 18 1.7 IE 1.6 32 16 1.5 N LIF 29 1.4 O ) IS P ) m E B d 14 1.3 F (dB 26 ( IG M 3 IN 1.2 U IP A R G E A 23 12 1.1 ( d B ) 1 20 10 0.9 17 0.8 100 1000 10000 100 1000 10000 Rbias (Ohms) Rbias (Ohms) Vdd=3V Vdd=5V Vdd=3V Vdd=5V For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com 5 Application Support: Phone: 1-800-ANALOG-D Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Gain, Noise Figure & Rbias @ 5900 MHz Output IP3 vs. Rbias @ 5900 MHz Gain, Noise Figure & Rbias @ 4800 MHz Output IP3 vs. Rbias @ 4800 MHz Gain, Power & Noise Figure vs. Supply Voltage @ 5900 MHz Gain, Power & Noise Figure vs. Supply Voltage @ 4800 MHz Power Compression @ 5900 MHz Power Compression @ 5900 MHz Power Compression @ 4800 MHz Output IP3 and Total Supply Current vs. Supply Voltage @ 5900 MHz Output IP3 and Total Supply Current vs. Supply Voltage @ 4800 MHz Output IP3 vs. Temperature Psat vs. Temperature P1dB vs. Temperature Noise Figure vs. Temperature Reverse Isolation vs. Temperature Output Return Loss vs. Temperature Input Return Loss vs. Temperature Gain vs. Temperature Gain vs. Temperature Broadband Gain & Return Loss Power Compression @ 4800 MHz Absolute Bias Resistor Range & Recommended Bias Resistor Values Absolute Maximum Ratings Typical Supply Current vs. Supply Voltage Outline Drawing Package Information Pin Descriptions Application Circuit Evaluation PCB List of Materials
