HMC717ALP3E v09.0816 Gaas pHEMT MMIC LOW NOIsEaMpLIFIER, 4.8 - 6.0 GHzabsolute Bias Resistor Range & Recommended Bias Resistor Values Rbias (Ohms) Vdd (V) Idd (mA) Min Max Recommended T 1.69k 20 M 3V 1.69k [1] Open Circuit 2.94k 26 5.76k 30 40.2 48.4 E - S 5V 40 [2] Open Circuit 562 65.5 825 72 IS [1] With Vdd= 3V and Rbias < 1.69kΩ may result in the part becoming conditionally stable which is not recommended. O [2] With Vdd = 5V and Rbias<40Ω may result in the part becoming conditionally stable which is not recommended. W N O absolute Maximum Ratings R - L Drain Bias Voltage (Vdd) +5.5V ELECTROSTATIC SENSITIVE DEVICE IE RF Input Power (RFIN) +20 dBm (Vdd = +5 Vdc) OBSERVE HANDLING PRECAUTIONS Channel Temperature 150 °C LIF Continuous Pdiss (T= 85 °C) P 0.52 W (derate 8.0 mW/°C above 85 °C) M Thermal Resistance 125 °C/W A (channel to ground paddle) Storage Temperature -65 to +150 °C Operating Temperature -40 to +85 °C ESD Sensitivity (HBM) Class 1A Typical supply Current vs. supply Voltage Rbias Vdd (V) Idd (mA) 2.7 20 5.76K 3.0 31 3.3 39 4.5 57 825 5.0 72 5.5 86 Note: Amplifier will operate over full voltage ranges shown above. For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com Application Support: Phone: 1-800-ANALOG-D 6 Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Gain, Noise Figure & Rbias @ 5900 MHz Output IP3 vs. Rbias @ 5900 MHz Gain, Noise Figure & Rbias @ 4800 MHz Output IP3 vs. Rbias @ 4800 MHz Gain, Power & Noise Figure vs. Supply Voltage @ 5900 MHz Gain, Power & Noise Figure vs. Supply Voltage @ 4800 MHz Power Compression @ 5900 MHz Power Compression @ 5900 MHz Power Compression @ 4800 MHz Output IP3 and Total Supply Current vs. Supply Voltage @ 5900 MHz Output IP3 and Total Supply Current vs. Supply Voltage @ 4800 MHz Output IP3 vs. Temperature Psat vs. Temperature P1dB vs. Temperature Noise Figure vs. Temperature Reverse Isolation vs. Temperature Output Return Loss vs. Temperature Input Return Loss vs. Temperature Gain vs. Temperature Gain vs. Temperature Broadband Gain & Return Loss Power Compression @ 4800 MHz Absolute Bias Resistor Range & Recommended Bias Resistor Values Absolute Maximum Ratings Typical Supply Current vs. Supply Voltage Outline Drawing Package Information Pin Descriptions Application Circuit Evaluation PCB List of Materials
