Datasheet HMC717ALP3E (Analog Devices) - 8
DescriptionGaAs pHEMT MMIC LOW NOISE AMPLIFIER, 4.8 - 6.0 GHz
Pages / Page11 / 8 — HMC717ALP3E. Gaas pHEMT MMIC LOW NOIsE. aMpLIFIER, 4.8 - 6.0 GHz. pin …
HMC717ALP3E. Gaas pHEMT MMIC LOW NOIsE. aMpLIFIER, 4.8 - 6.0 GHz. pin Descriptions
HMC717ALP3E Gaas pHEMT MMIC LOW NOIsE aMpLIFIER, 4.8 - 6.0 GHz pin Descriptions
HMC717ALP3E
v09.0816
Pin Number Function Description Interface Schematic 1, 3 - 7, 9, 10, No connection required. These pins may be connected N/C 12, 14, 16 to RF/DC ground without affecting performance. T M This pin is DC coupled 2 RFIN See the application circuit for off-chip component. E - S IS O This pin is used to set the DC current of the amplifier by 8 BIAS selection of the external bias resistor. See application circuit. W N O 11 RFOUT This pin is AC coupled and matched to 50 Ohms R - L IE Power supply voltage. Bypass capacitors are required. 13, 15 Vdd2, Vdd1 LIF See application circuit. P M A GND Package bottom must be connected to RF/DC ground For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com Application Support: Phone: 1-800-ANALOG-D
8
Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Gain, Noise Figure & Rbias @ 5900 MHz Output IP3 vs. Rbias @ 5900 MHz Gain, Noise Figure & Rbias @ 4800 MHz Output IP3 vs. Rbias @ 4800 MHz Gain, Power & Noise Figure vs. Supply Voltage @ 5900 MHz Gain, Power & Noise Figure vs. Supply Voltage @ 4800 MHz Power Compression @ 5900 MHz Power Compression @ 5900 MHz Power Compression @ 4800 MHz Output IP3 and Total Supply Current vs. Supply Voltage @ 5900 MHz Output IP3 and Total Supply Current vs. Supply Voltage @ 4800 MHz Output IP3 vs. Temperature Psat vs. Temperature P1dB vs. Temperature Noise Figure vs. Temperature Reverse Isolation vs. Temperature Output Return Loss vs. Temperature Input Return Loss vs. Temperature Gain vs. Temperature Gain vs. Temperature Broadband Gain & Return Loss Power Compression @ 4800 MHz Absolute Bias Resistor Range & Recommended Bias Resistor Values Absolute Maximum Ratings Typical Supply Current vs. Supply Voltage Outline Drawing Package Information Pin Descriptions Application Circuit Evaluation PCB List of Materials
