Datasheet ADL5721 (Analog Devices) - 3
Description5.9 GHz to 8.5 GHz, Low Noise Amplifier
Pages / Page15 / 3 — Data Sheet. ADL5721. SPECIFICATIONS AC SPECIFICATIONS. Table 1. …
File Format / SizePDF / 389 Kb
Data Sheet. ADL5721. SPECIFICATIONS AC SPECIFICATIONS. Table 1. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
Data Sheet ADL5721 SPECIFICATIONS AC SPECIFICATIONS Table 1 Parameter Test Conditions/Comments Min Typ Max Unit
TA = 25°C, VCC1 = 1.8 V, VCC2 = 3.3 V, ZSOURCE = 50 Ω, ZLOAD = 100 Ω differential, unless otherwise noted.
Table 1. Parameter Test Conditions/Comments Min Typ Max Unit
FREQUENCY RANGE Low Band, BAND = 0 V 5.9 7.2 GHz High Band, BAND = 1.8 V 7.1 8.5 GHz FREQUENCY = 5.9 GHz Low band, BAND = 0 V Gain (S21) 25.0 dB Noise Figure 1.7 dB Input Third-Order Intercept (IIP3) Δf = 1 MHz, input power (PIN) = −30 dBm per tone 4.3 dBm Input 1 dB Compression Point (P1dB) −10.6 dBm Input Return Loss (S11) 10 dB Output Return Loss (S22) 9 dB FREQUENCY = 7.2 GHz Low band, BAND = 0 V Gain (S21) 25.9 dB Noise Figure 1.6 dB Input Third-Order Intercept (IIP3) Δf = 1 MHz, PIN = −30 dBm per tone 4.0 dBm Input 1 dB Compression Point (P1dB) −9.3 dBm Input Return Loss (S11) 10 dB Output Return Loss (S22) 10 dB FREQUENCY = 8.5 GHz High band, BAND = 1.8 V Gain (S21) 24.6 dB Noise Figure 1.5 dB Input Third-Order Intercept (IIP3) Δf = 1 MHz, PIN = −30 dBm per tone 5.7 dBm Input 1 dB Compression Point (P1dB) −8.6 dBm Input Return Loss (S11) 10 dB Output Return Loss (S22) 10 dB
DC SPECIFICATIONS Table 2. Parameter Test Conditions/Comments Min Typ Max Unit
POWER INTERFACE VCC1 Voltage 1.65 1.8 1.95 V VCC2 Voltage 3.1 3.3 3.5 V Quiescent Current vs. Temperature VCC1 TA = 25°C 11.6 mA −40°C ≤ TA ≤ +85°C 12.1 mA VCC2 TA = 25°C 74.1 mA −40°C ≤ TA ≤ +85°C 74.4 mA Rev. 0 | Page 3 of 15 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS AC SPECIFICATIONS DC SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS LOW BAND (BAND = 0 V) HIGH BAND (BAND = 1.8 V) THEORY OF OPERATION APPLICATIONS INFORMATION LAYOUT DIFFERENTIAL vs. SINGLE-ENDED OUTPUT EVALUATION BOARD INITIAL SETUP RESULTS BASIC CONNECTIONS FOR OPERATION OUTLINE DIMENSIONS ORDERING GUIDE
