Datasheet HMC1049LP5E (Analog Devices)
Description | GaAs, pHEMT, MMIC, Low Noise Amplifier, 0.3 GHz to 20 GHz |
Pages / Page | 14 / 1 — GaAs, pHEMT, MMIC, Low Noise. Amplifier, 0.3 GHz to 20 GHz. Data Sheet. … |
Revision | B |
File Format / Size | PDF / 333 Kb |
GaAs, pHEMT, MMIC, Low Noise. Amplifier, 0.3 GHz to 20 GHz. Data Sheet. HMC1049LP5E. FEATURES. FUNCTIONAL BLOCK DIAGRAM
GaAs, pHEMT, MMIC, Low Noise Amplifier, 0.3 GHz to 20 GHz Data Sheet HMC1049LP5E FEATURES FUNCTIONAL BLOCK DIAGRAM 1 Low noise figure: 1.8 dB G C C C C C C C C P1dB output power: 14.5 dBm N N A N N N N N 32 31 30 29 28 27 26 25 PSAT output power: 17.5 dBm High gain: 15 dB NC 1 HMC1049LP5E 24 NC Output IP3: 29 dBm V 2 23 NC DD NC 3 22 GND Supply voltage: VDD = 7 V at 70 mA GND 4 21 RFOUT/VDD 50 Ω matched input/output (I/O) RFIN 5 20 NC 32-lead, 5 mm × 5 mm LFCSP package: 25 mm2 NC 6 19 NC NC 7 18 NC APPLICATIONS NC 8 17 NC Test instrumentation 9 10 11 12 13 14 15 16
2
High linearity microwave radios C C C C G C 3 2
00
N N N N G N G G
8-
V VSAT and SATCOM C C
679
A A
1
Military and space
Figure 1.
GENERAL DESCRIPTION
The HMC1049LP5E is a GaAs MMIC low noise amplifier image rejection mixers. VDD can also be applied to Pin 21, (LNA) that operates between 0.3 GHz and 20 GHz. This LNA although Pin 21 requires a bias tee with VDD = 4 V. The provides 15 dB of small signal gain, 1.8 dB noise figure, and an HMC1049LP5E amplifier I/Os are internally matched to 50 Ω, IP3 output of 29 dBm, yet requires only 70 mA from a 7 V and the device is supplied in a compact, leadless 5 mm × 5 mm supply. The P1dB output power of 14.5 dBm enables the LNA to LFCSP package. function as a local oscillator (LO) driver for balanced, I/Q, or
Rev. B Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2018 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Evaluation Printed Circuit Board Packaging and Ordering Information Outline Dimensions Ordering Guide
