Datasheet HMC1049 (Analog Devices) - 10
DescriptionGaAs pHEMT MMIC Low Noise Amplifier, 0.3 GHz to 20 GHz
Pages / Page14 / 10 — HMC1049. Data Sheet. TA = +85°C. TA = +25°C. TA = –55°C. SE (d. Bm). N …
RevisionB
File Format / SizePDF / 272 Kb
HMC1049. Data Sheet. TA = +85°C. TA = +25°C. TA = –55°C. SE (d. Bm). N –10. d 3 (. –15. ESPO R –20. –25. –30. S21. –35. S11 S22. –40. FREQUENCY (GHz)
HMC1049 Data Sheet TA = +85°C TA = +25°C TA = –55°C SE (d Bm) N –10 d 3 ( –15 ESPO R –20 –25 –30 S21 –35 S11 S22 –40 FREQUENCY (GHz)
HMC1049 Data Sheet
Data taken with VDD = 4 V applied to the bias tee at Pad 4.
20 35 TA = +85°C 15 TA = +25°C TA = –55°C 10 30 5 ) 0 B –5 25 SE (d Bm) N –10 d 3 ( –15 IP 20 ESPO R –20 –25 15 –30 S21 –35 S11 S22 –40 10 0 4 8 12 16 20 24
030
0 2 4 6 8 10 12 14 16 18 20
033
FREQUENCY (GHz)
12956-
FREQUENCY (GHz)
12956- Figure 28. Broadband Gain and Return Loss Figure 31. Output IP3 vs. Temperature
20 20 TA = +85°C TA = +85°C TA = +25°C TA = +25°C 18 TA = –55°C TA = –55°C 17 16 14 B) 14 d Bm) d N ( B ( AI 12 G 1d P 11 10 8 8 6 5 0 2 4 6 8 10 12 14 16 18 20 22
031
034
FREQUENCY (GHz)
12956-
FREQUENCY (GHz)
12956- Figure 29. Gain vs. Temperature Figure 32. P1dB vs. Temperature
6 23 TA = +85°C TA = +85°C TA = +25°C TA = +25°C TA = –55°C TA = –55°C 5 20 ) 4 dB ( E 17 R Bm) d 3 ( FIGU AT E SP 14 OIS 2 N 11 1 0 8 0 2 4 6 8 10 12 14 16 18 20
032
035
FREQUENCY (GHz)
12956-
FREQUENCY (GHz)
12956- Figure 30. Noise Figure vs. Temperature Figure 33. PSAT vs. Temperature Rev. B | Page 10 of 14 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Absolute Maximum Ratings ESD Caution PIN Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Application Circuit Assembly Diagram Mounting and Bonding Techniques for Millimeterwave GaAs MMICs Handling Precautions Storage Cleanliness Static Sensitivity Transients General Handling Mounting Eutectic Die Attach Epoxy Die Attach Wire Bonding Outline Dimensions Ordering Guide
