Datasheet HMC1049 (Analog Devices)
DescriptionGaAs pHEMT MMIC Low Noise Amplifier, 0.3 GHz to 20 GHz
Pages / Page14 / 1 — GaAs pHEMT MMIC Low Noise. Amplifier, 0.3 GHz to 20 GHz. Data Sheet. …
RevisionB
File Format / SizePDF / 272 Kb
GaAs pHEMT MMIC Low Noise. Amplifier, 0.3 GHz to 20 GHz. Data Sheet. HMC1049. FEATURES. FUNCTIONAL BLOCK DIAGRAM
Datasheet HMC1049 Analog Devices, Revision: B
GaAs pHEMT MMIC Low Noise Amplifier, 0.3 GHz to 20 GHz Data Sheet HMC1049 FEATURES FUNCTIONAL BLOCK DIAGRAM Low noise figure: 1.7 dB High gain: 16 dB 2 3 1 HMC1049 P1dB output power: 15 dBm DDV ACG Supply voltage: 7 V at 70 mA 4 RFOUT/V Output IP3: 27 dBm DD 50 Ω matched input/output Die size: 1.43 mm × 2.9 mm × 0.1 mm 3 2 APPLICATIONS 1 RFIN ACG ACG Point-to-point radios VGG 7 6 5
001
Point-to-multipoint radios
12956-
Military and space
Figure 1.
Test instrumentation GENERAL DESCRIPTION
The HMC1049 is a GaAs MMIC low noise amplifier (LNA) that VDD can be applied to Pad 2 with VDD = 7 V or to Pad 4 with operates between 0.3 GHz and 20 GHz. This LNA provides 16 dB VDD = 4 V. Pad 4 requires a bias tee. The HMC1049 is also of small signal gain, a 1.7 dB noise figure, and an Output IP3 of internal y matched to 50 Ω for ease of integration into multichip 27 dBm, requiring only 70 mA from a 7 V supply. The P1dB modules (MCMs). All data is taken with the chip in a 50 Ω test output power of 16 dBm enables the LNA to function as a local fixture connected via 0.025 mm (1 mil) diameter wire bonds of oscil ator (LO) driver for balanced, I/Q or image rejection mixers. 0.31 mm (12 mil) length.
Rev. B Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2015–2017 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Absolute Maximum Ratings ESD Caution PIN Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Application Circuit Assembly Diagram Mounting and Bonding Techniques for Millimeterwave GaAs MMICs Handling Precautions Storage Cleanliness Static Sensitivity Transients General Handling Mounting Eutectic Die Attach Epoxy Die Attach Wire Bonding Outline Dimensions Ordering Guide
