Datasheet HMC1040CHIPS (Analog Devices)
Description20 GHz to 44 GHz, GaAs, pHEMT, MMIC, Low Noise Amplifier
Pages / Page14 / 1 — 20 GHz to 44 GHz, GaAs, pHEMT, MMIC,. Low Noise Amplifier. Data Sheet. …
File Format / SizePDF / 351 Kb
20 GHz to 44 GHz, GaAs, pHEMT, MMIC,. Low Noise Amplifier. Data Sheet. HMC1040CHIPS. FEATURES. FUNCTIONAL BLOCK DIAGRAM
Datasheet HMC1040CHIPS Analog Devices
20 GHz to 44 GHz, GaAs, pHEMT, MMIC, Low Noise Amplifier Data Sheet HMC1040CHIPS FEATURES FUNCTIONAL BLOCK DIAGRAM Low noise figure: 2 dB typical 2 3 4 High gain: 25.0 dB typical 1 2 3 DD DD DD P1dB output power: 13.5 dBm, 24 GHz to 40 GHz V V V High output IP3: 25.5 dBm typical Die size: 1.309 mm × 1.48 × 0.102 mm RFIN 1 APPLICATIONS 5 RFOUT Software defined radios HMC1040CHIPS Electronic warfare Radar applications
001
Satellite communication
16709-
Electronic warfare
Figure 1.
Instrumentation Telecommunications GENERAL DESCRIPTION
The HMC1040CHIPS is a gallium arsenide (GaAs), output power (PSAT) of 15.5 dBm enables the low noise amplifier pseudomorphic high electron mobility transistor (pHEMT), (LNA) to function as a local oscil ator (LO) driver for many of monolithic microwave integrated circuit (MMIC), low noise Analog Devices, Inc., balanced, in phase quadrature (I/Q) or wideband amplifier that operates from 20 GHz to 44 GHz. The image rejection mixers. HMC1040CHIPS is self biased and provides a typical gain The HMC1040CHIPS also feature inputs and outputs that are of 25.0 dB, a 2 dB typical noise figure, and a typical output internal y matched to 50 Ω, making it ideal for surface-mounted third-order intercept (IP3) of 25.5 dBm typical, requiring technology (SMT)-based, high capacity microwave radio only 65 mA from a 2.5 V supply voltage. The typical saturated applications.
Rev. 0 Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2018 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS 20 GHz TO 24 GHz FREQUENCY RANGE 24 GHz TO 32 GHz FREQUENCY RANGE 32 GHz TO 40 GHz FREQUENCY RANGE 40 GHz TO 44 GHz FREQUENCY RANGE ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION RECOMMENDED BIAS SEQUENCING MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GaAs MMICS Handling Precautions TYPICAL APPLICATION CIRCUIT ASSEMBLY DIAGRAM OUTLINE DIMENSIONS ORDERING GUIDE
