Datasheet HMC1040CHIPS (Analog Devices) - 9
Description20 GHz to 44 GHz, GaAs, pHEMT, MMIC, Low Noise Amplifier
Pages / Page14 / 9 — Data Sheet. HMC1040CHIPS. Bm). d (. B (. 2.0V. 2.5V. 3.0V. FREQUENCY …
File Format / SizePDF / 351 Kb
Data Sheet. HMC1040CHIPS. Bm). d (. B (. 2.0V. 2.5V. 3.0V. FREQUENCY (GHz). E (%. OUT. GAIN. PAE. mA). I DD. –15. –13. –11. INPUT POWER (dBm). 0.15. 0.14. 0.13
Data Sheet HMC1040CHIPS Bm) d ( B ( 2.0V 2.5V 3.0V FREQUENCY (GHz) E (% OUT GAIN PAE mA) I DD –15 –13 –11 INPUT POWER (dBm) 0.15 0.14 0.13
Data Sheet HMC1040CHIPS 18 18 16 16 14 14 12 Bm) 12 Bm) d d ( B ( AT 1d 10 S 10 P P 2.0V 2.0V 8 2.5V 8 2.5V 3.0V 3.0V 6 6 4 4 20 22 24 26 28 30 32 34 36 38 40 42 44
019
022
FREQUENCY (GHz)
16709-
FREQUENCY (GHz)
16709- Figure 19. P1dB vs. Frequency for Various Supply Voltages Figure 22. PSAT vs. Frequency for Various Supply Voltages
28 74 24 74 24 72 20 72 ) ) P P E (% OUT E (% OUT GAIN GAIN 20 70 16 70 PA PAE PA PAE ), I ), I B DD B DD (d (d mA) mA) IN 16 68 ( IN 12 68 ( A A G I DD G I DD ), ), B B 12 66 8 66 (d (d UT UT O O P P 8 64 4 64 4 62 0 62 –15 –13 –11 –9 –7 –5
020
–15 –13 –11 –9 –7 –5 –3 –1
023
INPUT POWER (dBm) INPUT POWER (dBm)
16709- 16709- Figure 20. Output Power (POUT), Gain, Power Added Efficiency (PAE), and IDD Figure 23. POUT, Gain, PAE, and IDD with RF Applied vs. Input Power at 42 GHz with RF Applied vs. Input Power at 22 GHz
28 74 0.15 0.14 24 72 ) P ) 0.13 E (% OUT GAIN 20 70 (W PA PAE N ), I B DD IO 0.12 T (d mA) IN 16 68 PA ( 22GHz A 0.11 24GHz G I DD ISSI ), 26GHz B D 28GHz 12 66 0.10 (d ER 30GHz UT W 32GHz OP PO 0.09 34GHz 8 64 36GHz 38GHz 0.08 40GHz 42GHz 4 62 –15 –13 –11 –9 –7 –5 –3
021
0.07 INPUT POWER (dBm) –15 –14 –13 –12 –11 –10 –9 –8 –7 –6 –5 –4 –3 –2
024 16709-
INPUT POWER (dBm)
16709- Figure 21. POUT, Gain, PAE, and IDD with RF Applied vs. Input Power at 33 GHz Figure 24. Power Dissipation vs. Input Power for Various Frequencies, TA = 85°C Rev. 0 | Page 9 of 14 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS 20 GHz TO 24 GHz FREQUENCY RANGE 24 GHz TO 32 GHz FREQUENCY RANGE 32 GHz TO 40 GHz FREQUENCY RANGE 40 GHz TO 44 GHz FREQUENCY RANGE ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION RECOMMENDED BIAS SEQUENCING MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GaAs MMICS Handling Precautions TYPICAL APPLICATION CIRCUIT ASSEMBLY DIAGRAM OUTLINE DIMENSIONS ORDERING GUIDE
